本帖最後由 chijeng 於 2015年5月28日 08:43 AM 編輯
請教各位大大,小弟手邊目前有顆 Dualsky XM5060EA-6 470Kv 馬達,如果要可以停旋的話,請問適合裝在哪一級數的J-3上? 謝謝
| Kv (rpm/volt): | 470 | | Alias - stator dia, magnet length (mm): | 4130 | | Slots, Poles: | 12, 14 | | Weight (gr): | 393 | | Idle Current @10V (Amps): | 2.4 | | Motor Diameter (mm): | 49 | | Motor Length (mm): | 58 | | Motor Shaft Dia. (mm): | 6 | | Prop Adapter Dia. (mm): | 8 | | Mounting Hole Pitch (mm): | 30/30 | | Resistance (mOhm): | 15 | | Lipo Cells: | 6 | | Continuous Power (Watts): | 1017 | | Burst Current, 15 seconds (Amps): | 83 | | Burst Power, 15 seconds (Watts): | 1849 | | Max Prop Size: | 5S: 16x12 / 6S: 15x8 | | Max Model Weight - Sport: | 5.1kg / 11.25lbs | | Max Model Weight - 3D: | 3.4kg / 7.5lbs | | Glow Equiv (cu in): | .75-.90 2-stroke/ 1.10 4-stroke |
▼ 下一篇:可乘人.的飛毯機就是愛DIY▲ 上一篇:
