查看: 5374166|回復: 10
很小的cat
發表於 2006年12月6日 04:27 PM | 顯示全部樓層 |閱讀模式
ELECTRIC POWERED MICRO RACING BOAT MINI-Z CATAMARAN BOAT
MINI-Z CATAMARAN BOAT Readyset
No.40202LC-40   Readyset
□Available : 29 Dec 2006
Developed in collaboration with LAMBORGHINI! How fast can you go with a CATAMARAN boat that fits on the palm of your hand?
The latest addition to the same MINI-Z formula boats from Kyosho that made such a big splash the world over comes in the form of a racing cat developed in collaboration with Lamborghini. But don't let the palm-top size deceive you as this mighty miniature produces amazing speed and performance. The high-tech lightweight design features a powerful motor that combines with a high-thrust propeller to drive the twin-stepped hull for awesome high speed planing. With the adoption of the a special drive unit with adjustable thrust angle, advanced settings are made possible for true racing cat like performance. The unsinkable structure of the hull is equipped with a waterproof hatch to the radio box and motor room so the sensitive electronics are not compromised. The model is also completely pre-assembled and comes with a boat stand that doubles as a quick battery charger, so all you need are batteries for the transmitter.
Advanced 2-stepped racing cat hull design produces acceleration and stability way beyond its size.
Ultra-compact hull is packed with high-tech components protected by a waterproof hatch.
Features adjustable thrust angle. Optional flaps allow further setting of the hull's posture. (0 degree flap is included as standard).
  • Fully finished Readyset package only requires batteries to operate.
  • Stable and responsive control is realized with the FM27MHz BET band R/C system.
  • Moisture-resistant one-piece receiver/amp delivers stable control.
  • Features drive unit with adjustable thrust angle.
  • Waterproof hatch maintains integrity of onboard electronics and motor.
  • Hull structure features built-in buoyancy making it unsinkable.
  • Includes realistic pre-painted pilot figure.
  • Load 8 x AA-sized alkaline batteries (sold separately) into the dual-purpose boat trailer / battery charger and charge for 3 minutes to fully charge.
  • The trailer / charger is designed so it can be towed by the MINI-Z Overland SUV's.
  • Set the deck and slide the intakes to lock the ports.
< Readyset Contents >
  • Pre-colored factory assembled hull
  • Pre-installed KT-7 2-ch, One-piece amp./receiver R/C system
  • Pre-installed SHO30SA Motor
  • 6V-150mAh Ni-MH battery
  • Combined trailer/quick charger can also be used as boat stand
  • * AAA-size x8 for transmitter, and AAA-size x 8 batteries for quick charger are sold separately.
Technical Data
Length
225mm
Width
76mm
Height
52mm
Weight
106g (approx.)
Motor
SHO30SA
R/C System
KT-7 2-ch 1-servo
Screw
D15×P0.8
* Do not operate the model in salt water as this may cause damage.
□Last updated:10 Aug 2006
上一篇:小時玩的馬達
下一篇:給 ST8872
發表於 2006年12月6日 04:44 PM | 顯示全部樓層
這台哪有賣ㄋ..價格
 樓主| 發表於 2006年12月6日 04:55 PM | 顯示全部樓層
原帖由 ST8872 於 2006年12月6日 04:44 PM 發表
這台哪有賣ㄋ..價格
29 Dec 2006 應該是這個月會上市! ~ 應該是跟之前f1差不多!
Kyosho 1/25 Formula Boat 迷你遙控競艇    首頁 >
售價 : $ 3,900
  加入購物車
迷你遙控競艇.組裝完成含FM遙控器全套配件
品牌 : KYOSHO單位 :
產地 : CHINA貨號 : KY40401TG-30
完成度 : 100%完成品週邊配件 : 全配 / 另購AA(單3號)電池16顆
遙控器 : KYOSHO / PERFEX 2CH電池 : 本體用6V-130mah
充電器 : 拖車台充電座
發表於 2006年12月6日 05:14 PM | 顯示全部樓層
那黃色那台能在戶外玩ㄇ..會很勉強ㄇ
我是蠻想在另外接觸電動船
之前討論區裡褾題是我看上這隻貓
有問過你面那台覺得還蠻可愛
有發文詢問何處可購得.規格.配備
但沒人回我
 樓主| 發表於 2006年12月6日 06:11 PM | 顯示全部樓層
原帖由 ST8872 於 2006年12月6日 05:14 PM 發表
那黃色那台能在戶外玩ㄇ..會很勉強ㄇ
我是蠻想在另外接觸電動船
之前討論區裡褾題是我看上這隻貓
有問過你面那台覺得還蠻可愛
有發文詢問何處可購得.規格.配備
但沒人回我
這裡可以問看看!
http://www.speed-rc.com.tw/front/bin/ptdetail.phtml?Category=96471&Part=03F
若要玩小船需要很平浪的水域,如魚池之類的,否則對小船會有很大的考驗!
歡迎你進入船模的領域,大家會熱心幫忙的!
發表於 2006年12月6日 06:16 PM | 顯示全部樓層
原帖由 s91401102 於 2006年12月6日 18:11 發表
這裡可以問看看!
http://www.speed-rc.com.tw/front ... =96471&Part=03F
歡迎你進入船模的領 ...
那台小貓叫什ㄇㄋ
GMT+8, 2025年6月12日 07:00 PM
