查看: 4147|回復: 0
【童愛模型】GW SBACH342 50CC V2碳纖版 B塗裝,特價14500元
發表於 2014年5月26日 11:02 AM | 顯示全部樓層 |閱讀模式
WING SPAN89" (2260mm)
LENGTH86-3/4"(2205mm)
WING AREA1483sq in(95.7sq dm)
FLYING WEIGHT16.5-17.8lbs (7500-8100g)
ENGINE50-70cc gasDLE55 DLE61 DA50 DA60 EME60 GP61
Electric Power:
   Hacker Q80-8mwith 12S 5000mAh 24*10 prop
   KUZA EXM 8015 with 12S 5000mAh 24*10 prop
   Or other 4000Watt electric motor
   ESC: 160A
RADIO4+CH/5-6S
The new V2 version of SBACH342has the following Improvements from previon version:
1.Control services islarger than V1 version. Up to 50 degrees of throw on all control surfaces. Bestfor more vibrant aerobatic flight.
2.Improved wheels with more durablematerials and filled with rubber.
3.Using high qualitycap head screws.
4.Improved ball link assembly.
5.Improved new Axlethe material of Axle is stainless steel.
6.Improved new DualFiberglass horn assembly.
7.Flat nylon hingesfor better flying strength.
8.IncludeSide Force Generator's(SFG)
9.Larger carbon fiber wing tube diameter than V1 previon version.
10.This V2 new design with a longer fuselage moment arm aiding the tracking ofthe model,giving it rock sold precision flight.Making it perfect for modern dayflight schedules for IMAC and Freestyle
上一篇:【童愛店舖】 金翼GW YAK55M 30CC,特價7200元
下一篇:【童愛模型】150~170CC機翼袋
GMT+8, 2025年12月26日 06:45 PM
