查看: 1570|回復: 4
[物品交換] PLUS U5-112數位單槍投影機
發表於 2014年4月18日 05:37 PM | 顯示全部樓層 |閱讀模式
本帖最後由 yao59 於 2014年10月11日 07:17 AM 編輯
PLUS U5-112數位單槍投影機
9.5成新
燈泡已使用時數30小時
原廠全配
附電源線.VGA線 .S線
提包
遙控器
說明書
光碟使用說明
(拍賣刊登中)各位大大:想要高解析度1080p又要便宜那是不可能的事(請搜尋目前正1080p DMD影像晶片高解機種價格)
[url=]詳細規格[/url]
SpecificationsU5-112U5-111
Projection SystemDLPTM
PanelDMD SVGA x 1
解析度800 pixels x 600 pixels
亮度Normal mode: 1600 lm
(Eco-mode: approximately 20% less 亮度)
對比2000:1 (Full on/off)
投影比例4:3, supports 16:9
鏡頭F2.6-2.9, f= 20-24 mm
1:1.2 Manual Zoom, Manual Focus
F2.6, f= 19 mm
Manual Focus
Light Resource200-watt High Performance Compact Lamp
Color Palette16.7 million colors
Projecting PositionFront/Rear, Table/Ceiling
投影距離1.2-11.1 m1.2-10.6 m
投影大小28"-300" diagonal34"-300" diagonal
RGB Signal (Input)XGA (Compression), SVGA (True), VGA (Expansion/True)
Video SignalNTSC3.58, NTSC4.43, PAL, PAL_N, PAL_M, PAL60, SECAM,
YCbCr (NTSC, PAL), YPbPr (480p, 576p, 1080i, 720p)
Horizontal Synch Range15-80 kHz
Vertical Synch Range50-85 Hz
AudioMono 0.8-watt
輸入端子RGB/YCbCr/YPbPr: Mini D-Sub 15 pin x 1
Composite Video: RCA x 1
S-Video: Mini DIN 4 pin x 1
Audio (RGB/Video): ø3.5 mm Stereo Mini Jack x 1
Remote Mouse: USB Mini-B x 1
ColorSilver
大小60 mm (H) x 216 mm (W) x 240 mm (L)
重量1.9 kg
Power Supply100-240 V AC at 50/60 Hz
Power Consumption280 watts (Normal mode), 250 watts (Eco-mode)
Environment32-95 ºF/5-35 ºC
On-Screen Display LanguagesEnglish/German/French/Italian/Spanish/Swedish/Korean/Chinese/Japanese
FunctionsFull-Auto Adjustment
Digital Keystone Correction (20 degrees)
Digital Zoom (2x)
Freeze
Mute
Quick Color Adjustment
Presentation Timer
Security Password
AccessoriesLens Cap x 1
IR Remote Control (Card type) x 1
CR2025 (3V Lithium Battery) x 1 (for Remote Control)
Power Cable (1.8 m) x 1
VGA Cable (Mini D-sub 15 pin/2 m) x 1
S-Video Cable (Mini DIN 4 pin/2 m) x 1
Video Cable (RCA/2 m) x 1
Audio Cable (ø3.5 mm Mini Plug/2 m) x 1
Mini Jack to RCA Adapter (ø3.5 mm Stereo Mini Jack - RCA/0.15 m) x 1
Soft Case x 1
User's Manual (CD-ROM) x 1
User's Manual (Simplified Edition) x 1
Optional AccessoriesCeiling Mount Kit
User-Replaceable Lamp Unit
上一篇:[800含運]~交易中~JR RG611B接收機
下一篇:(9000) 京商1/8軸傳油車
 樓主| 發表於 2014年5月7日 08:46 AM | 顯示全部樓層
踢上去~~意者可提出預換物品及圖照~~
 樓主| 發表於 2014年10月11日 07:18 AM | 顯示全部樓層
~意者可提出預換物品及圖照~~
發表於 2014年11月15日 10:50 PM | 顯示全部樓層
用級數高一階的Benq PB-2240跟您換如何? 樹林區  詳情 回復 發表於 2014年11月16日 09:16 PM
 樓主| 發表於 2014年11月16日 09:16 PM | 顯示全部樓層
hiphop666666 發表於 2014年11月15日 10:50 PM
http://www.rctw.net/thread-340710-1-1.html  這可以嗎
GMT+8, 2025年12月31日 11:10 AM
