查看: 4756|回復: 10
哈哈~V BAR 也出一隻大V控
發表於 2014年2月20日 07:40 PM | 顯示全部樓層 |閱讀模式
本帖最後由 lsb1575 於 2014年2月21日 02:18 PM 編輯
V BAR 陀螺儀稱霸直升機界
現在也出一支大V控來搭配
SKY_RANGER UH1
颶風255電調設定問題?
發表於 2014年2月20日 09:03 PM | 顯示全部樓層
酷呀!不過好像只能接VBAR的陀螺儀?
 樓主| 發表於 2014年2月20日 09:20 PM | 顯示全部樓層
賴仔 發表於 2014年2月20日 09:03 PM
酷呀!不過好像只能接VBAR的陀螺儀?
好像使用2.4GHz FHSS系統!!
有解說看不大懂!!
Software Highlights:
  • Set up, programming and adjusting of VBar-controlled model helicopters accomplished directly via VBar Control transmitter.
  • No computer, control panel or smartphone necessary.
  • Instant access to almost every flight parameter from the transmitter controls, even in flight.
  • Easy programming for new helicopters via the familiar VBar setup wizard.
  • New ESC setup wizard for programming all types of speed controllers.
  • Bank switching with three banks.
  • Real time logging and real time vibration analysis readable from the transmitter.
  • Several telemetry functions are available, such as voltages, current, rpm, speed, and power consumption of the batteries (may need aditional hardware).
  • Storage of event log files like VBar event log, VBar Control event log, GPS way points, voltage/current logging etc.
  • Multiple timer functions available with warnings and reminders via sound, voice, or vibration output.
  • Wireless buddy boxing with two VBar Control transmitters, fully configurable.
  • Easy bind process, allows bind and fly of any model equipped with VBar Control (e.g. a buddy‘s heli) with your own transmitter (Model Sharing).
  • Software updates via internet using a simple VBar Control Manager app and the web browser.
  • Option for adding new features via apps, simple installation via internet, supports both Windows and Mac OS X-PCs, no drivers needed.
  • Additional airplane software will be available in summer 2014.
Hardware Highlights:
  • 80 Channel 2.4 GHz FHSS bidirectional flight control, programming/setup and telemetry remote control system.
  • VBar Control Satellite Receiver connects directly to VBar flybarless controller via 2.4GHz VBar-Link protocol.
  • Unlimited model memory.
  • Virtually unlimited number of control channels.
  • High range, low latency, antenna diversity on both transmitter and receiver.
  • Intelligent antenna monitoring and management.
  • XXtra Bright Graphic Display featuring high contrast and ambient light sensor to automatically control the display brightness, making it equally well readable in bright sunlight and in the dark.
  • Easy Dialog System with rotary dial for convenient and safe inputs, with optical, tactile and acoustic feedback.
  • Precision gimbals with four ball bearings, fully adjustable.
  • Collective stick equipped with optional throw limiter.
  • Fully equipped with four 3-position-switches, two quick-break-switches and two rotation knobs, all fully programmable.
  • Delicate rubber lining for comfortable, slip-free and safe holding.
  • 3-point neck-strap attachment, for optimum balance.
  • Large 2 Watt loudspeaker for alarms and voice output.
  • Vibration alarm (adjustable).
  • Internal 8 MB flash memory.
  • Memory accessible as a USB memory stick, no drivers needed.
  • 4.000 mAh Lithium Polymer battery allows for long run times.
  • Charge through USB connector or built-in charger.
  • Power Supply for fast charging included.
發表於 2014年2月20日 09:43 PM | 顯示全部樓層
一定不便宜呀 !
發表於 2014年2月21日 07:22 AM | 顯示全部樓層
好像是可以在搖控器上直接調整你要的轉速
而機體的轉速會回傳至搖控
然後機體的零活度也可以直接從搖控調
不需接電腦
還有就是像亞拓6j那樣已經將他們所有的機種的設定參數寫到搖控中!
但主要因該還是要解決在外場設定要用電腦的問題吧!
發表於 2014年2月21日 08:31 AM | 顯示全部樓層
來個狗屁不通的GOOGLE翻譯
軟件亮點:
設置,編程的直條遙控模型直升機和調整通過直條控制發射器直接完成的。
沒有電腦,控制面板或必要的智能手機。
即時訪問來自發射機的控制幾乎所有的飛行參數,即使是在飛行。
通過熟悉的直條設置嚮導易於編程的新型直升機。
編程所有類型的速度控制器的新ESC鍵設置嚮導。
銀行交換與三家銀行。
即時記錄和實時振動分析從發射器可讀。
一些遙測功能都可用,如電壓,電流,轉速,速度和電池的消耗功率(可能需要aditional的硬件)。
像直條事件記錄,直條控件的事件日誌, GPS航點,電壓/電流記錄等事件日誌文件存儲
多個定時器功能可用,但有警告和提醒通過聲音,語音或振動輸出。
無線哥們拳擊有兩個直條控制發射器,完全可配置的。
簡單的綁定過程,允許綁定,並配備了直條控件(例如一個哥們的直升機)用自己的發射器(型號共用)任何型號的飛。
用一個簡單的直條控制管理應用程序和Web瀏覽器通過互聯網的軟件更新。
選項通過應用程序添加新功能,通過網絡安裝簡單,同時支持Windows和Mac OS X的電腦,無需驅動程序需要。
額外的飛機軟件將在2014年夏天。
硬件亮點:
80通道的2.4GHz FHSS雙向飛行控制,編程/設置和遙測遙控系統。
直條控制衛星接收機直接通過2.4GHz的直條鏈路協議連接到直條無副翼控制。
無限模式記憶。
幾乎無限數量的控制通道。
高量程,低延時,發射器和接收器的天線分集。
智能天線的監控和管理。
XXtra明亮的圖形顯示具有高對比度和環境光傳感器,自動控制顯示屏的亮度,使它同樣可讀在明亮的陽光和黑暗。
簡單的對話系統與旋轉轉盤,方便,安全投入,光學,觸覺和聲音反饋。
精密平衡環與四球軸承,完全可調。
集體棍配備了可選的投限制器。
配備了4個3位置開關,雙速斷開關和兩個旋轉旋鈕,所有的完全可編程。
玲瓏橡膠襯裡舒適,防滑,自由和安全舉行。
3點頸帶附件,以獲得最佳的平衡。
大2瓦揚聲器進行報警和語音輸出。
振動報警(可調) 。
內置8 MB閃存。
訪問作為USB記憶棒存儲,無需驅動程序。
4.000毫安時鋰聚合物電池可以長時間的運行時間。
充電通過USB接口或內置充電器。
電源快速充電包括在內
GMT+8, 2026年2月28日 01:23 PM
