查看: 5350|回復: 35
@@BLADE 350 QX AP Combo RTF 敬請期待
發表於 2014年2月1日 12:50 AM | 顯示全部樓層 |閱讀模式
本帖最後由 DKCK 於 2014年2月1日 01:15 AM 編輯
更多商品,請至<DKCK專區按我進入>參觀
原廠終於搞全套了..再等等
Blade 2014 Product Preview(200 SR X RTF / 300 CFX BNF Basic  /  200 QX BL /  350 QX AP Combo RTF)
  • ncluded 2-Axis Brushless Gimbal
  • Included C-Go 1 Camera 1080P/30
  • 5.8Ghz Wi-Fi Video Downlink to Supported Devices
  • Large 3S 3000mAh Flight Battery
  • Improved Receiver with External Antenna
  • Improved GPS
  • Visual Compass Error Detection
  • Compatible with All Spektrum Radios
包括2軸萬向無刷雲台
包括C-Go相機1080/30 camera with 720/30 video
5.8GHz Wi-Fi Video下行到支持的設備
3S 3000mAh的電池
接收器改進外部天線
改進的GPS
指南針錯誤檢測
兼容所有SPEKTRUM 控
Following our passion for innovating convenient ways to fly, we have taken the Blade 350 QX to the next level. Introducing the 350 QX AP Combo RTF, a fully integrated aerial photography solution. We’ve listened to the customer and built that feedback into the next generation of the 350 QX.
This model includes a plethora of new features including:
• 2-axis brushless gimbal with optional pitch control
• 1080/30 camera with 720/30 video downlink to mobile devices
• 3S 3000 mAh flight battery for extended shoots
• New DX4 Transmitter
The 350 QX AP Combo also takes on a host of upgrades to the existing system including:
• New RF chipset with external antenna
• Improved GPS performance and accuracy
• Visual compass error detection to alert the user for calibration
• Simplified radio solution for ease of use
• Included AC/DC charging solution
• White battery hatch for improved orientation
The 350 QX AP Combo captures incredible aerial footage without any of the hassle of buying several components and is backed by the best support in the industry should you ever need it. Feel free to stop looking, you’ve found the perfect AP solution for your fleet!
Smart Mode: GPS/Altitude Hold, SAFE™ Circle feature and Stick Relativity
AP Mode: Limited flight envelope, self-leveling and GPS/Altitude Hold. Damped, self-leveling for improved video quality.
Stability Mode: Limited flight envelope, self-leveling and GPS hold.
Return Home and Land: Returns the 350 QX to the home position and lands at the pilots command.
下面我們對創新便捷的方式飛翔的激情,我們所採取的刀片350 QX到一個新的水平。引入350 QX AP組合RTF ,一個完全集成的航空攝影解決方案。我們聽取了客戶和內置的反饋到下一代的350 QX 。
該模型包括了大量的新功能,包括:
• 2軸萬向節無刷可選音調控制
1080/30 camera with 720/30 video 下行鏈路到移動設備
• 3S 3000毫安時的飛行電池延長
•新DX4遙控器
350 QX AP組合也需要一個主機升級包括現有系統上:
•新的RF芯片組與外部天線
•改進的GPS性能和精度
•視覺指南針錯誤檢測,提醒校準的用戶
•易於使用的簡化無線電解決方案
•包括交流/直流充電解決方案
•白色的電池艙蓋的改進方向
350 QX AP二合一捕捉令人難以置信的空中鏡頭,沒有任何買幾個組件的麻煩,是由在同行業中最好的支持為後盾,您都不需要它。隨意停止尋找,你已經找到了你的艦隊完美的AP解決方案!
智能模式: GPS /高度保持, SAFE™圈的功能和相對論棒
AP模式:有限的飛行包線,自平​​和GPS /高度保持。阻尼,自流平​​,以提高視頻質量。
穩定模式:有限的飛行包線,自流平​​和GPS擱置。
回家和土地:返回350 QX到飛行員命令的位置和土地。
產品規格
類型:無刷MUTLI旋翼飛機
主旋翼直徑: 22.8 ( 580毫米)
毛重: 35.5盎司( 1006克)
上一篇:DKCK新春營業時間~馬倒成功~
下一篇:@@ BLADE 200 QX BL 中四軸 敬請期待@@
 樓主| 發表於 2014年2月1日 12:59 AM | 顯示全部樓層
發表於 2014年2月1日 01:15 AM | 顯示全部樓層
350qx飛控我很喜歡,價格好像不便宜耶!定價快一千美金不是嗎?不知可以飛多久?雲台可另外出售否?
 樓主| 發表於 2014年2月1日 01:36 AM | 顯示全部樓層
aegistw 發表於 2014年2月1日 01:15 AM
350qx飛控我很喜歡,價格好像不便宜耶!定價快一千美金不是嗎?不知可以飛多久?雲台可另外出售否? ...
FPV RTF版大概就是這個價錢,低於NTD3萬,具體售價會再訂出,目前尚未有零件表出來
目前只看到一個像機是可以零售的
5.8Ghz downlink to support mobile devices with included antenna
1080P/30 recording or 720P/30 when streaming
Lightweight and small form factor
Low latency and long range Wi-Fi
Overview
Introducing the perfect Action camera for your RC needs! Whether you are looking for a lightweight FPV camera with streaming capabilities that won’t interfere with your 2.4 radio or just looking for a high quality action camera, the E-Flite C-GO1 is destined to be the # 1 choice of modelers everywhere.
5.8GHz的下行鏈路,以支持與包括天線的移動設備
像機1080P/30或攝影720P/30
輕便小巧的外形
低延遲和長距離的Wi-Fi
概觀
介紹了完美的動作相機為您的RC需求!無論您正在尋找一個輕量級的FPV攝像頭,支持流媒體功能,不會干擾你的2.4無線電或只是為了尋找一個高品質攝像頭的動作,在E-Flite公司的C-GO1注定是排名第一的選擇。
發表於 2014年2月1日 07:15 AM | 顯示全部樓層
全套有包含雲台相機......
發表於 2014年2月1日 07:50 PM | 顯示全部樓層
現有的350QX可升級到350QX AP的FW嗎?
GMT+8, 2025年12月6日 01:06 AM
