查看: 2183|回復: 0
大基隆模型 SR-9/100'' - 已到貨
發表於 2014年1月3日 06:17 PM | 顯示全部樓層 |閱讀模式
大基隆模型 SR-9/100''  已到貨 歡迎洽詢
更多商品請看 - 大基隆模型 RC專區 -
Stinson Reliant
Design and development
The Reliant is a three-place high-wing fixed tailwheel land monoplane powered with a variety of radial engines.
1,327 Reliants of all types were made from 1933 to 1941, in different models, from SR-1 to SR-10.
The final commercial model, the Stinson Reliant SR-10, was introduced in 1938. A militarized version was first flown in February 1942 and remained in production through several additional versions (all externally identical) until late 1943 for the US and British armed forces.
Reliant production can be broken into two distinct types - the straight wing Reliants (all models up to SR-6) and the gull wing Reliants
(all models from SR-7 and after including the militarized V-77/AT-19) with there being little in common between the two groups of types. The straight wing Reliant had a wing of constant chord and thickness which was supported by two struts each side with additional bracing struts. In contrast the taper wing Reliant had the broadest chord and thickness of the wing at mid span,
with the outer wing trailing edge heavily angled forward and a rounded cutout on the leading edge root,
all supported by a single strut. The taper wing had a significant step up between the fuselage and the wing,
and the changes in wing thickness gave it a distinct gull appearance from the front.
Wing Span:
100" (2540mm)
Length:
71" (1803mm)
Wing area:
10.4 sq. ft. (96.4 sq. dm.)
Wing Loading:
27.2oz/sq.ft. (83g/sq.dm.)
Flying Weight:
17.6 lbs. (8kg)*Weight Information
Radio:
6 ch & 8 servos
Gas Engine:
36cc - 55cc engine. The PTE-36 and the DLE-55 are two good  options. The PTE-36 will make the plane a nice flier. It you want unlimited  vertical and the ultimate in over-performance then the DLE-55 is a good  choice.
Glow Engine:
1.08 2 cycle or 1.20 4 cycle
Prop Recommendations:
2-blade is scale.
Servo Recommendations:
100 oz-sq-in minimum - HD-1501, Hitec 645MG, Hitec 5645MG,  DS-8309TG
上一篇:大基隆模型 TIGER MOTH 88" 德哈維蘭虎蛾機 - 已到貨
下一篇:[12000含運] FUTABA- 4PK -2.4G+ 2 收信機
GMT+8, 2025年12月5日 05:04 AM
