查看: 1952671|回復: 9
X-35 所取代機種
發表於 2006年10月16日 01:05 PM | 顯示全部樓層 |閱讀模式
DESCRIPTION:
The Joint Strike Fighter program was started to replace a myriad of aircraft for the US Air Force, US Navy, US Marines, and the British Royal Navy beginning around 2010. Since each branch hoping to acquire the JSF has different needs, each variant of the aircraft will be tailored to the requirements of that service. The USAF is planning to acquire some 1,760 conventional takeoff attack fighter variants to replace the F-16 and A-10 while the Navy and Marines are looking to replace older models of the F/A-18. The Navy's approximately 300 to 480 aircraft will be generally similar to the Air Force model but will carry more fuel for greater range. The Marines also need about 480 vertical/short takeoff and landing (V/STOL) aircraft to replace its fleet of AV-8B Harriers, so its version will feature a ducted lift-fan to assist in vertical flight. The Royal Navy is also interested in purchasing about 60 V/STOL models to replace the Harrier while the Royal Air Force plans to acquire another 90 to replace its Harrier fleet.
F-16 Fighting Falcon
A-10 Thunderbolt
A-10 Thunderbolt
F/A-18 Hornet
F/A-18 Hornet
AV-8B Harrier
AV-8B Harrier
Sea-Harrier
Sea-Harrier
X-35 英姿
X-35 英姿
上一篇:美國未來四十年主力戰機 X-35
下一篇:噴射機失事影集試貼
發表於 2006年10月16日 03:56 PM | 顯示全部樓層
超強戰機~~~~
發表於 2006年10月16日 07:07 PM | 顯示全部樓層
我記得F-22是取代空軍的現有機種, X-35是取代海軍的現有機種, 不曉得對不對!!
 樓主| 發表於 2006年10月16日 07:36 PM | 顯示全部樓層
取代
原帖由 Mel 於 2006年10月16日 07:07 PM 發表
DESCRIPTION:
[wma] [hrr]to replace [/hrr][/wma]the F-16 and A-10 while the Navy and Marines are looking [hrr][hrr]to replace [/hrr][/hrr]older models of the F/A-18. The Navy's approximately 300 to 480 aircraft will be generally similar to the Air Force model but will carry more fuel for greater range. The Marines also need about 480 vertical/short takeoff and landing (V/STOL) aircraft [hrr]to replace [/hrr]its fleet of AV-8B Harriers, so its version will feature a ducted lift-fan to assist in vertical flight. The Royal Navy is also interested in purchasing about 60 V/STOL models [hrr]to replace [/hrr]the Harrier while the Royal Air Force plans to acquire another 90 to replace its Harrier fleet.
以上這份說明是從美國軍事網站下載言明取代 F-16,  A-10,  F/A18,  AV-8B Harrier(美國艦載 )及英國艦載 Harrier
發表於 2006年10月16日 09:18 PM | 顯示全部樓層
所以說~我們台灣都跟人家買垃圾!!!!!!!!!!!!!!!!!
發表於 2006年10月16日 11:07 PM | 顯示全部樓層
GMT+8, 2025年11月14日 07:20 AM
