查看: 1329|回復: 1
ul1 哪裡買?
發表於 2013年12月8日 11:13 PM | 顯示全部樓層 |閱讀模式
https://www.youtube.com/watch?v=rOA8UCdt05M
ul1 有大大知道哪裡買嗎??  有她的詳細規格嗎??
上一篇:好天氣, 所以要去曬太陽
下一篇:真的不行嗎?
發表於 2013年12月8日 11:45 PM | 顯示全部樓層
FEATURES: Hull: Lightweight painted fiberglass with molded-in center tub            section that houses the motor, batteries and radio equipment,            breakaway fins detach under stress to prevent damage to the hull,            attach with two-sided tape and float for easy retrieval          Motor: AquaCraft 6-pole 36-56-2030kV brushless marine motor created            exclusively for the UL-1 and high-speed hauling, 4mm motor plugs            boost efficiency          Radio: Tactic TTX-240 2.4GHz system, 2-ch pistol grip transmitter            with steering and throttle, and steering trim adjustment, Tactic            TSX200 standard servo for rudder control, Tactic TR324 3-channel            receiver          Electronic Speed Control: Water cooled, waterproof, 60A for LiPo            usage, a "Stutter Bump" warning at 12V and an auto cut-off at 11.6V            insure low voltage protection, ESC is also NiCd and NiMH compatible          Strut: Black anodized CNC-machined aluminum, adjustable to change            prop depth and angle to match water conditions          Turn Fin: 0.08" (2mm) thick aluminum with tapered leading edge to            reduce drag, adjustable for top performance          Cowl: ABS plastic with magnetic locking system          Propeller: 3-blade          Warranty: Ninety day limited
GMT+8, 2026年1月12日 06:14 AM
