本帖最後由 leif1209 於 2014年5月18日 08:47 PM 編輯
F4U包含所有的電裝
有掉漆 自行買漆 上色 即可
掉漆是在組裝 過程 手抓太緊而把漆刮下來
它是EPO 所以僅有表面的漆掉了 結構無損傷
完全沒有飛過, 只有拆開組裝而已
全配 僅缺接收 遙控器 及電池(7.4V)
飛機 馬達 聯接電變已完成 尾翼已接合
僅主翼接合 及接收 裝上 即可
如果有意願 請回復
The Famous F4U Corsair in a totally new style!
The HobbyKing F4U Corsair is a very neatly designed EPO parkflyer. This Plug-n-Fly R/C plane comes with a brushless outrunner, ESC and servos all pre-installed. All you need is a 2S battery and receiver.
Build time is around 15 minutes and does not require glue.
The tough EPO construction keeps the model bouncing back for more and the strong 2607 outrunner motor provides plenty of power on as little as a 1,000mAh 2S LiPo.
Specification:
Wing Span: 800mm (31.5in)
Length: 660mm (26in)
Weight: 420g
Motor: 2607 Brushless outrunner 1400kv
Prop: 3-Blade
ESC: 10A brushless
Battery: 7.4V 1000mAh 2S1P (Not included)
Battery compartment size: 99x33x20mm
Servos: 5g x 3
Required:
Your TX & RX
7.4V 2S 1000mah lipo battery
網站簡介:
http://www點hobbyking點com/hobbyking/store/uh_viewitem點asp?idproduct=16290
上一篇:[150]起賣無刷3顆馬達下一篇:已售出
