查看: 1097|回復: 0
【童愛模型】美國3dhs 42" Slick 橘色塗裝~特價4800元
發表於 2013年12月1日 09:55 PM | 顯示全部樓層 |閱讀模式
組裝說明書
http://www.3dhobbyshop.com/asset ... -42SLICK-Manual.pdf
Specs:
Wingspan: 42"
Length: 38"
Weight: 30-36oz
Wing Area: 375 sq in
Required Equipment
Motors: Omega 103g1030KV w/12x6 prop Recommended
Hacker A30-16M w/11x5.5 prop
Omega 72g1100KV w/ 11x5.5 prop
ESC:
Hacker X40
Airboss 45
Castle Ice Lite 50
Battery:
3S Lipo 1500-2100mah
Servos:
Hitec HS-65MG Recommended
Hitec HS-65HB
Hitec HS-45HB
Servo extensions:
1 x 12" servo extensions
1 x 6" servo extension
2 x 4" servo extensions
Servo notes:
The HS-45HB is only for use with very light setups such as the 72g Omega or 480-sized outrunners. Being a very light servo, it requires perfect installation for best performance. The HS-65MG is a heavier, but much more rugged servo that is more forgiving of less-than-perfect installation
連絡方式:0912-278833蔡先生
到貨日:12/23
【童愛模型】美國3dhs 42" Slick 紅色塗裝~特價4800元
【童愛模型】金翼新機預告,歡迎預訂
GMT+8, 2026年3月7日 07:59 AM
