查看: 862|回復: 0
【童愛模型】美國3dhs 87" Extra 紅色塗裝~特價22100
發表於 2013年12月1日 04:56 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年12月1日 05:50 PM 編輯
組裝說明書
http://www.3dhobbyshop.com/asset ... -87EXTRA-MANUAL.pdf
Specs
Wingspan: 87"
Length: 87"
Wing area: 1475 Sq. Inches
Weight 16-18 lbs (depending on setup)
Required Equipment
Engine:
DA-60
DA-50
DLE-55
Note: The 87" Extra is set up for the DA-50 engine. This engine provides excellent performance and bolts on with stock 3" standoffs.
The DA-60 provides extreme performance with no weight penalty and is recommended. The DA-60 is NOT the same length as the DA-50 and does not mount the same way. For DA-60 mounting photos see this URL:
DA-60 Mounting Photos
The 87" kit includes a generic fuel tank, but American-made Fourtitude fuel tanks are the best and are a recommended upgrade.
Electric Power System:
Hacker Q80-8M Motor - 24 x 10 prop
Castle Creations ICE HV160 ESC
12S 5000mah Lipo (Two 6S 5000mah running in series)
Servos:
QTY 5 Hitec HS-7955TG
Servo Arms:
QTY 1 SWB 4" Offset for Rudder
QTY 2 SWB 2" Single Sided for Elevators
QTY 2 SWB 1.5" Single Sided for Ailerons
Extensions:
QTY 2 52" For Elevators
QTY 2 20" For Ailerons
QTY 2 8" For Ailerons (Rx side)
QTY 1 20" For Throttle or ESC
QTY 1 12" For Rudder
Spinner:
3.5"
★買就有送原廠機翼袋
連絡方式:0912-278833蔡先生
到貨日:12/23
上一篇:【童愛模型】美國3dhs 104" Slick 紅色塗裝~特價36800
下一篇:【童愛模型】美國3dhs 87" Extra 藍色塗裝~特價22100
GMT+8, 2025年6月20日 03:22 AM
