查看: 1452|回復: 4
[13500]代友出售全新 RC4WD TF2 Trail Finder 2 Truck Kit
發表於 2013年10月22日 03:48 PM | 顯示全部樓層 |閱讀模式
本帖最後由 artlesstw 於 2013年11月5日 11:50 AM 編輯
RC4WD TF2 Trail Finder 2 Truck Kit 全新未組裝
貨到付款免運費
Adventures can happen anywhere. Nothing will give you more fun in the sand, dirt, snow, or mud than the Trail Finder 2.
Part scale truck, part adventurer, your TF2 is ready for your mud kicking trail-loving lifestyle!The TF2 has both detailed styling and aggressive performance.
You will find a balance of capability and performance built into every TF2.
Performance of the TF2 is smooth and with its 2 speed selectable transmission, 4WD drivetrain, bullet-proof transfer case
and quality metal components throughout.
The TF2 is truly a work of art in both appearance and performance.Every TF2 is compatible with a full range of option and performance parts designed to enhance the performance
and add to the scale look of the only true scale 1/10 offroad truck... The Trailfinder 2. Your adventure awaits....Custom Designed for True-to-Scale LooksRealistic Billet Aluminum Ladder Frame Chassis2 Speed Remote Selectable TransmissionCenter Mounted Realistic 4x4 Transfer CaseCast Metal Axles with Locked DifferentialsTrue to Scale Leaf Spring SuspensionHighly Detailed Body with Dropped Bed and More1.55 Stamped Steel Beadlock Wheels with Lug NutsSuper Grip High Performance Mud Thrasher TiresRealistic Tube Bumpers - Rock Rails - Skid Plate
All New Hammer Transfer CaseRatio -        1.47:1 Gears - Wide 32P steel gears Features - 8 bearings, cast casing, hardened gearsAll New R3 2 Speed TransmissionRatios Pinion/spur 14/64 = 4.57:1 1st gear3.47:1 2nd gear        1.27:1Gears - Wide steel 32P, Delrin spur, slipper clutch,Features - Machined billet aluminum casing, scale looking, Motor mount can be rotated to 10 different positions,
compatible with other brand spurs (Axial, Traxxas, Robinson)Cast Yota AxlesRatio: 15/40 = 2.67:1 Width at hex (using 4mm TF2 hexes): 176.5mmAll New Trailfinder 2 ChassisFeatures - Billet aluminum constriction Adjustable shock hoopsDriveshaftsHigh quality plastic material, very durable High quality steel YokesWheelsName: 1.55 OEM beadlock wheels Hub:        12mm hex Width: 22mm Back spacing: 9mmFeatures: Stamped steel, aluminum hub, internal beadlock, very scale looking, 6 bolt pattern,BumpersTough Armor TF2 Winch front bumper Tough Armor TF2 Rear Bumper Tough Armor TF2 Side Sliders Authentic
looking crawler style tube bumper. Very high quality flexible plastic, very durable, very scale.TF2 Truck DimensionsWheels base: 287mm (11.3") Width:215mm (8.5") Height: 210mm (8.25")Ground clearance: 57mm (2.5")Final Drive Ratios: 1st - 62.1:1, 2nd - 22.75:1
DRIVETRAINThe TF2 includes the new Hammer Transfer Case. Packed with detail, the case features a cast metal exterior and the same
new 32P widened gears for durability.The most scale accurate axles on the market, the RC4WD Cast Yota axles feature innovative round knuckles,
new lower mounting points and compact offset pumpkins.The All New R3 2 speed transmission comes with a fully machined billet aluminum case and new wider gears to allow for
more abuse along with a Delrin spur with slipper clutch. The new designed motor mount is adjustable in 10 positions.Drawing on the success of the RC4WD MOA gear sets, the TF2 drivetrain has the most durable
gears RC4WD has to offer so the TF2 will stay on the trail, day after day.The Driveshafts for the TF2 are an all new design featuring bulletproof steel universals and a new high quality plastic shaft
for great driveline angles and durability on the trail.
SUSPENSIONThe TF2 includes a set of RC4WD Ultimate Scale Shocks. Designed for ultimate scale looks and ultimate performance.
Machined from billet aluminum, rebuildable and internally sprung.The TF2 includes a set of RC4WD White Stamped Steel 1.55 internal beadlock wheels. Super tough paintable white finish,
aluminum internal ring and popular 6 lug design.The TF2 Chassis features a molded fuel cell that doubles as an electronics storage box plus an aluminum, frame-mounted
under cab electronics tray for multiple electronics mounting options.The All New TF2 Chassis is a machined billet alumi- num ladder frame design with leaf springs, scale shock hoops,
chassis servo mounts and hard body mounts. 4-link conversion available soon!Every TF2 needs a tough set or rock grabbing tires and the included Mud Thrashers in X3 Compound deliver
the traction as well as perfect scale looks in just the right size.
DETAILSThe TF2 Mojave body features new late model style square headlights, chrome bumpers
and a redesigned shape of the classic 4x4 body style.
More accurately proportioned and better details.Another industry first, the TF2 Mojave Body Set includes a bolt on, scale accurate molded cab back with every kit
so you can use just the cab for a truggy style build.The Mojave Body Set includes add on windshield wipers, mirrors, marker light details
and door handles for the ultimate in scale looks.
These items are also easily replaceable if damaged.The TF2 Mojave Body Set includes an industry first dropped bed molded directly into the body.
Perfect for carrying all you scale accessories or spare wheel and tire.The Trailfinder 2 kit also includes all new scale rock rails plus front and rear tube rock guard bumpers.
The front bumper has a winch mount built right in for an optional RC4WD winch.
Courtesy photo provided by RC Sparks.
Courtesy photo provided by Rbgerrish from the NWSC. Decked out TF2.
上一篇:[79元限量]香香香、一秒香、新型專利快速芳香免插電免加...
下一篇:[500]雷虎原廠四極馬達 4074 規格2000kv
發表於 2013年10月22日 04:04 PM | 顯示全部樓層
好車推一個!
發表於 2013年10月22日 06:29 PM | 顯示全部樓層
心動~
 樓主| 發表於 2013年10月22日 06:33 PM | 顯示全部樓層
zunlin 發表於 2013年10月22日 06:29 PM
心動~
感謝推文,心動…不如馬上行動哦。
 樓主| 發表於 2013年10月23日 02:31 PM | 顯示全部樓層
artlesstw 發表於 2013年10月22日 06:33 PM
感謝推文,心動…不如馬上行動哦。
新增實物照片,全新未拆封
GMT+8, 2025年12月30日 04:02 PM
