查看: 2565|回復: 3
2015 F3A新科目及講解
發表於 2013年9月24日 03:17 PM | 顯示全部樓層 |閱讀模式
F3A初賽2014-2015 P科目
Preliminary Schedule P-15 (2014-2015) K-Factor
P-15.01 Golf Ball with two ½ rolls高爾夫球各邊1/2滾正飛出                                                              K 3
P-15.02 Half Square Loop on Corner with ½ roll 菱形尾頂端1/2滾倒飛出                                             K 3
P-15.03 Double Immelman with two knife-edge flights  兩個伊麥曼進出點各做1/4滾正飛出                    K 5
P-15.04 Half Square Loop with ½ roll 半個方形觔斗加1/2滾正飛出                                                      K 2
P-15.05 Stall Turn with 1¼ roll up, ¾ roll down   失速倒轉向上1¼ 滾向下 ¾滾正飛出                            K 5
P-15.06 Reverse Cuban 8 with ½ roll  反古巴八字加1/2滾正飛出                                                         K 2
P-15.07 Roll Combination with consecutive three 1/6 rolls, three 1/6 rolls in opposite direction               K 5
        連續3個1/6滾加上反向3個1/6滾正飛出
P-15.08 Pull-Push-Push Humpty-Bump with ¾ roll up, ¾ roll down (Option: ½ roll up, ½ roll down)        K 4
        駝峰各邊3/4滾倒飛出(Option:各邊1/2滾)
P-15.09 Top Hat Inverted Spin with 2½ turns 上帽型加負spin2½圈正飛出                                             K 4
P-15.10 Pull-Knife-Edge-Push Humpty-Bump with ½ roll down 駝峰半個側飛loop向下1/2滾倒飛出          K 4
P-15.11 Reverse Cuban 8 with consecutive two ¼ rolls, consecutive two ½ rolls in
opposite directions  反古巴,第一段直線2個連續1/4點滾第二段直線正反1/2點滾正飛出                            K 4
P-15.12 Figure 9 with consecutive four ¼ rolls up九字型向上直線4個1/4點滾倒飛出                                K 3
P-15.13 Hour-Glass with ½ roll, roll, ½ roll 沙漏形狀頂端直線1/2滾,向下斜線全滾,底部直線1/2滾倒飛出    K 4
P-15.14 Stall Turn with consecutive two ¼ rolls down失速倒轉加連續兩個1/4向下點滾正飛出                   K 3
P-15.15 45° Upline with consecutive two rolls in opposite directions  向上斜45度加正反全滾正飛出           K 4
P-15.16 Split S with ½ roll   1/2滾加上破S正飛出        K 1
P-15.17 Avalanche with snap roll on top     雪崩頂端一圈蛇滾(正負SNAP都可)                                         K 4
Total K 60
上一篇:加州Hollister pattern contest 9/14-9/15/13
下一篇:102年9月28,29日宜蘭飛行場
 樓主| 發表於 2013年9月24日 03:21 PM | 顯示全部樓層
甲組2014-2015科目
Advanced Schedule A-14 (2013-2014) K-Factor
A-14.01 Golf Ball 高爾夫球        K 3
A-14.02 Half Square Loop on Corner 菱形尾        K 3
A-14.03 Double Immelman with ½ roll, roll 倒飛出兩個伊麥曼上航線全滾下航線半滾正飛出                  K 5
A-14.04 Half Square Loop with ½ roll半個方形觔斗加1/2滾正飛出                                                       K 2
A-14.05 Stall Turn with ¼ roll up, ¼ roll down  失速倒轉上下各1/4滾正飛出                                         K 5
A-14.06 Reverse Cuban 8 with ½ roll  反古巴八字加1/2滾正飛出                                                        K 2
A-14.07 Roll Combination with consecutive three ¼ rolls, three ¼ rolls in opposite direction                  K 5
       連續3個1/4滾加上反向3個1/4滾正飛出
A-14.08 Pull-Push-Pull Humpty-Bump with ¼ roll up, ¼ roll down (Option: ½ roll up)                            K 4
       駝峰各邊1/4滾(option:向下1/2滾) 正飛出
A-14.09 Top Hat Spin with 3 turns上帽型加spin 3圈正飛出        K 4
A-14.10 Pull-Pull-Push Humpty-Bump with ½ roll down駝峰各邊1/4滾倒飛出                                       K 4
A-14.11 Reverse Cuban 8 with roll, ½ roll反古巴,第一段直線全滾第二段直線1/2滾正飛出                      K 4
A-14.12 Figure 9 with roll up九字型向上直線一個全滾倒飛出                                                               K 3
A-14.13 Hour-Glass沙漏形狀倒飛出        K 4
A-14.14 Stall Turn with ½ roll down失速倒轉加1/2向下滾正飛出                                                           K 3
A-14.15 45° Upline with slow roll   向上斜45度一圈慢滾正飛出                                                             K 4
A-14.16 Split S with ½ roll  1/2滾加上破S正飛出        K 1
A-14.17 Avalanche with snap roll on top   雪崩頂端一圈蛇滾(正負SNAP都可)                                        K 4
Total K 60
 樓主| 發表於 2013年9月24日 03:27 PM | 顯示全部樓層
F3A半決賽2014-2015 F
Semi-Final and Final Schedule F-15 (2014-2015) K-Factor
F-15.01 Double Immelman with ½ rolls in both ½ loops integrated, two consecutive two ¼
rolls in opposite direction to integrated rolls.        K 4
F-15.02 Stall Turn with consecutive three ¼ rolls up, 1 ¼ snap rolls down                                               K 3
F-15.03 Golf Ball with two ¾ roll up, knife-edge loop with snap roll, ¾ roll down                                        K 5
F-15.04 Half Square Loop with consecutive two snap rolls in opposite directions                                      K 4
F-15.05 Loop with consecutive two ½ rolls in opposite directions integrated                                             K 4
F-15.06 Inverted Spin with 2½ turns, ½ roll down        K 3
F-15.07 Horizontal Triangular Circle with ¼ roll, ½ outside rolls in each corner integrated                          K 6
F-15.08 Top Hat with consecutive two ¼ rolls up, snap roll down
(Option: Consecutive three ¼ rolls up, 1¼ snap roll down)        K 4
F-15.09 Vertical Cuban 8 with consecutive four rolls up, consecutive two ½ rolls down                           K 4
F-15.10 Half Square Loop on Corner with ½ roll integrated in ¼ loop                                                        K 4
F-15.11 Horizontal Hour-Glass with consecutive two ¼ rolls, two ¼ rolls in opposite direction
consecutive two ¾ rolls in opposite directions        K 4
F-15.12 Half Square Loop with consecutive two ½ rolls        K 3
F-15.13 Figure 9 with consecutive four ¼ rolls up, ¾ loop with roll integrated in top 180°                            K 6
F-15.14 Split S with 1½ snap roll        K 3
F-15.15 Roll Combination with consecutive four rolls in opposite directions                                               K 5
F-15.16 Pull-Pull-Push Humpty-Bump with two ½ roll in opposite direction up, roll down                            K 3
F-15.17 Stall Turn with consecutive six rolls up, 1¾ snap roll down                                                       K 5
        Total K 70
發表於 2013年9月26日 06:36 AM | 顯示全部樓層
感謝分享
GMT+8, 2025年12月30日 08:38 PM
