查看: 1001|回復: 0
【童愛模型】美國3dhs 59寸Slick~紅色塗裝~特價9600元
發表於 2013年9月11日 10:34 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年9月12日 11:23 PM 編輯
到貨時間為10月7日,歡迎預訂
組裝說明書
https://3dhobbyshop.3dcartstores ... -59Slick-Manual.pdf
Wingspan:
59" (1500mm)
Length:
54" (1370mm)
Weight:
4.25-4.75 lbs. (1930-2155g)
Channels:
4,5
Good: Neo 46-580, 14x7
Better: Hacker A40 10S, 14x7
TP3900 4S
63mm/2 1/2" spinner
The 50-Size/59" Andrew Jesky AJ Slick has taken the electric aerobatic world by storm. This is the high performance small aerobatic aircraft that you are looking for. Big enough to track with tremendous stability and shrug off gusty winds, the Slick still fits into your compact car. Andrew Jesky designed the 51" Slick to have the aerobatic features of a giant scale aerobatic plane in both precision and 3D flight. The recommended setup on 4S Li-poly is extremely powerful and gives the Slick serious vertical performance. All ball-link hardware is included for very precise control and the carbon fiber landing gear is anchored to a fiberglass-reinforced block assembly. The removable wings ride on a strong carbon fiber tube spar. Real ultracote covering, included wing bags, and a precision throw meter round out the package - which gives incredible bang for your RC buck.
Andrew Jesky (2009 and 2010 USA F3A pattern champion, 2008 ETOC champion, and Shootout invitational pilot) designed the AJ Slick to have the aerobatic features of a giant scale aerobatic plane in both precision and 3D flight.
Special Features:
- Control surfaces: Ailerons, Elevator and Rudder
- Fully illustrated, step-by-step instruction manual
- Complete hardware package
- Carbon fiber landing gear
- Lightweight balsa/ply construction
- Pre-painted fiberglass cowl and wheel pants
- Removable two piece plug-in wings
- Covered in authentic UltraCote
- High contrast color scheme
More information (links):
* Building Instructions
Airfoil : Symmetrical
Wing area : 660 sq.in.
Wing loading : 14.5-15.5 oz/sq.ft.
Empty weight : 42 oz. (1200g)
Suggested Equipment:
(1) Hacker A40 10S
(1) Hacker X-70 SB Pro ESC
(1) TP3900 4S battery
(4) HS-5245MG servo
(1) Heavy duty arm set (DUB672)
(1) TY 2 1/2" White spinner
(1) APC-E 14x7 propeller
(1) Deans connector
(1) 18" Servo extension
(1) 9" Servo extension
(2) 6" Servo extension
(1) Velcro strap (Esprit)
上一篇:【童愛模型】美國3dhs 59寸Slick~橘色塗裝~特價9600元
下一篇:【童愛模型】美國3dhs 72" Extra 330SC~紅色塗裝~特價14100元
GMT+8, 2025年12月30日 01:31 PM
