查看: 1394|回復: 3
【童愛模型】美國3dhs 48寸EPP Extra~特價4160元
發表於 2013年9月11日 10:12 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年9月12日 11:45 AM 編輯
組裝說明書
https://3dhobbyshop.3dcartstores ... 0Extra%20Manual.pdf
Wingspan:
48" (1220mm)
Length:
50.25" (1275mm)
Weight:
36-40 oz. (1020-1140g)
Channels:
4,5
Good: Hacker A30 14L, 14x7
Better: Omega 700W/870, 14x7
TP2250 3S
40mm/1 1/2" spinner
The 48" EPP Extra 330 is the first in a new line of aircraft from 3DHobbyShop. Built at the world's premier EPP production facility, the 48" employs built up EPP foam structure with a carbon backbone, carbon wing tube, removable airfoiled wings, carbon stiffening in the wings, fuse, and tail, SFG's - which all combine to give superb flight performance and serious durability. With the removable wings, transporting is easy and assembly at the field takes less than a minute. Extra uses the most common sizes of battery and servos so you probably already have most of the necessary equipment. A magnetic top hatch makes battery changes quick and easy for lots of uninterrupted flying - and considering what a superb high performance 3D practice plane this is, you will want to fly nonstop. The Extra is extra rugged, the EPP foam and carbon backbone technology mean you can survive most hard crashes with little or no repair work to do. Spring steel landing gear help soak up the hard hits too, while large free rolling wheels allow use from a variety of surfaces.
Either as your next step up from flat EPP foam planes, a fantastic practice plane, or your no-worries go-to hardcore aerobatics plane, the Extras delivers with super-low coupling, extremely easy 3D and good speed and handling in gusty winds. Give the Extra a try, you will fall in love with it!
Special Features:
- Control surfaces: Ailerons, Elevator and Rudder
- Fully illustrated, step-by-step instruction manual
- Complete hardware package
- Removable two piece plug-in wings
- Full built-up EPP construction with CF backbone
- Spring steel landing gear
- Indestructible EPP construction
- High contrast color scheme
More information (links):
* Building Instructions
Airfoil : Symmetrical
Wing area : 445 sq.in.
Wing loading: 11.5-13 oz/sq.ft.
Empty weight: 24 oz. (680g)
Suggested Equipment:
(1) Omega 700W/870 130g
(1) Hacker X-55 SB Pro ESC
(1) TP2250 3S battery
(4) SAVOX SH-0257MG servo
(1) TY 1 1/2" Red transparent spinner
(1) APC-E 14x7 propeller
(1) Deans connector
(2) 12" Servo extension
(2) 6" Servo extension
(1) Velcro strap (Esprit)
上一篇:分享3d hobby shop最新影片
下一篇:【童愛模型】美國3dhs 47寸 Extra~特價5440元
發表於 2013年10月9日 09:13 PM | 顯示全部樓層
請問有含电裝嗎?謝謝。
發表於 2013年10月11日 11:22 PM | 顯示全部樓層
是没在賣了嗎?怎麼都没回應??????
 樓主| 發表於 2013年10月17日 09:58 PM | 顯示全部樓層
葉大同 發表於 2013年10月11日 11:22 PM
是没在賣了嗎?怎麼都没回應??????
不含電裝.10月9日去上海,這二天才回來,不好意思
GMT+8, 2025年12月30日 08:07 AM
