查看: 6544|回復: 17
Goblin 500套裝版 體驗價$25350
發表於 2013年8月6日 03:59 PM | 顯示全部樓層 |閱讀模式
                                    Sab Goblin 500 Flybarless Electric Helicopter Yellow/Black Kit Combo [SG504]
$975.00  $845.00
General Specifications
Electronic Specifications
Main rotor diameter:  1136mm (with 500 mm blades)
HPS Head (FBL Only)
Main blade length: 470 to 500mm
Tail rotor diameter: 226 mm
Tail blade length: 80 mm
Main shaft diameter: 10 mm
Tail shaft diameter: 5 mm
Spindle shaft diameter: 8 mm
Gear Ratios 6.9-11 : 1
Weight including electronics: 1900 g (excluding flight battery).
18T motor pulley included (other pulley sizes available)
All pulleys are made for 6 mm motor shaft (5 mm motor shaft adapter included in kit)
Special Features:
Full carbon fiber boom
Quick release battery tray system
Sacrificial breaking point for landing gear and boom
Unique “inside the boom” tail push rod design
• Cyclic Servos: Mini size (36mm)
             Normal and 3D Flight: Hitec 5245 MG, Align DS510M or DS515M, Savox SH1250, Graupner DES 678 MG, MKS DS-9660A, Futaba 9650
              HARD 3D: Futaba BLS153, Graupner HBS660 HV, JR DS3717 HV, HITEC 7245 MG HV, JR DS3711 HV
• Tail Servo: Standard size (40mm)
• Typical Speed Controller: 80/100A
              Normal and 3D Flight: Kontronik Koby 90, YGE 100 LV
              HARD 3D: Kontronik Jive 100 LV, YGE 120 LV, CC Talon 90
• Motors: (Max Diameter: 52 mm, Max Height: 52 mm)
              Normal and 3D Flight: Scorpion HK-4015-1070, Quantum 4115-1200
              HARD 3D: PYRO 600-1200, Scorpion, HKIII-4020-1100/1350, Quantum 4120-1200
• Flight Battery: (Max Dimensions: 52x53x180mm)
              6S 2800/4500 mAh.
Kit Includes:
18T motor pulley (other pulley sizes available)
500 mm main blades
80 mm tail blades
The following motor pulleys are available:
16T Pulley (P/N 0215-16-S) Ratio 10.33:1
18T Pulley (P/N H0215-18-S) Ratio 9.18:1
20T Pulley (P/N H0215-20-S) Ratio 8.26:1
22T Pulley (P/N H0215-22-S) Ratio 7.51:1
24T Pulley (P/N H0215-24-S) Ratio 6.91:1
17T Pulley (P/N H0215-17-S) Ratio 9.72:1
19T Pulley (P/N H0215-19-S) Ratio 8.7:1
21T Pulley (P/N H0215-21-S) Ratio 7.87:1
23T Pulley (P/N H0215-23-S) Ratio 7.19:1
                                              All these motor pulleys are for a 6 mm motor shaft. Each pulley includes an adapter for 5 mm motor shafts.
• Identical concept as Goblin 700
• Simple and effective design
• Carbon fiber boom for maximum rigidity
• HPS (High Precision Head System)
• 10mm high strength steel main shaft
• 8mm high strength steel spindle shaft
• Large tail pulleys for increased tail authority
• Dampened tail system for increased vibration tolerance
• Unique, extremely rigid transmission design
• Stiffness of the model defined by a single component
• Heat tolerant primary drive belt
• Carbon fiber tail push rod hidden inside the boom for an aesthetically pleasing, unique design
• Nylon bolt break-away system to preserve the boom during a crash
• Landing gear mounting brackets don’t require bolts to be installed. The brackets are a break point during a crash preserving frames and other important parts
• Quick release battery tray system
• Plenty of room for electronic components
• Mini size cyclic servos
• Direct and geometrically correct servo placement
• Standard size tail servo
上一篇:[24000] SAB GOBLIN 700再加碼送原廠機袋與帽子一頂
下一篇:市面上最夯格式店池6S 5000mah 60C 大特價
 樓主| 發表於 2013年8月7日 04:25 AM | 顯示全部樓層
很多飛友詢問我,BK伺服器跟Servo King 795 &795i有什麼不同。
答案是沒有不同。 Goblin 500套裝版付的伺服器只是改了包裝多了Bert Kamermer的英文縮寫名, B.K。
SAB首次推出套裝版,價格$845美金非常的優惠,但只限首次推出combo體驗價來回饋飛友們。  本代理也只分到6套,賣完為止。  往後同樣的套裝版將回到正常售價$975美金,約台幣$29300。
想入手小毒蛇G500請趕緊下手,錯過了就不在有如此的體驗優惠價。
順便告訴飛友們,只剩4套。
發表於 2013年8月7日 03:39 PM | 顯示全部樓層
想入手的朋友手腳要快哦…毒蛇是很好的機子……我有一隻700的。
 樓主| 發表於 2013年8月7日 10:09 PM | 顯示全部樓層
感謝幫推。。。。。剩2套Goblin 500套裝版
發表於 2013年8月7日 11:19 PM | 顯示全部樓層
benyangsab700 發表於 2013年8月7日 10:09 PM
不客氣喔……你以定要照顧你的會員哦
發表於 2013年8月8日 12:47 AM | 顯示全部樓層
請問套裝包含什麼?.......................
GMT+8, 2025年12月31日 01:32 PM
