查看: 1269|回復: 2
【童愛模型】美國3dhs 71寸油電二用AJ slick540,特價14100元
發表於 2013年7月22日 03:41 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年8月11日 10:00 PM 編輯
【童愛模型】美國3d hobby shop 71寸AJ slick540 ETOC比賽用機,性能和準度各方面都很完美,就連高手都夢寐以求想要嚐試,亞洲開賣了,機會難得
第一批預計8月15日到貨,橘色和紅色款各限量一台
Wingspan:
71" (1800mm)
Length:
70" (1780mm)
Weight:
9.5-10 lbs. (4315-4540g)
Channels:
4,5
Good: O.S.Max 50 5020-490, 16x10
Better: Hacker A50 16S, 16x10
TP5000 6S
75mm/3" spinner The 90-Size/71" Andrew Jesky AJ Slick has taken the electric aerobatic world by storm. This is the high performance small aerobatic aircraft that you are looking for. Big enough to track with tremendous stability and shrug off gusty winds, the Slick still fits into your compact car. Andrew Jesky designed the 71" Slick to have the aerobatic features of a giant scale aerobatic plane in both precision and 3D flight. The recommended setup on 6S Li-poly is extremely powerful and gives the Slick serious vertical performance. All ball-link hardware is included for very precise control and the carbon fiber landing gear is anchored to a fiberglass-reinforced block assembly. The removable wings ride on a strong carbon fiber tube spar. Real Ultracote covering, included wing bags, and a precision throw meter round out the package - which gives incredible bang for your RC buck.
Andrew Jesky (2009 and 2010 USA F3A pattern champion, 2008 ETOC champion, and Shootout invitational pilot) designed the 71" Slick to have the aerobatic features of a giant scale aerobatic plane in both precision and 3D flight.
Special Features:
- Control surfaces: Ailerons, Elevator and Rudder
- Fully illustrated, step-by-step instruction manual
- Complete hardware package
- Carbon fiber landing gear
- Lightweight balsa/ply construction
- Pre-painted fiberglass cowl and wheel pants
- Removable two piece plug-in wings
- Covered in authentic UltraCote
- High contrast color scheme
More information (links):
* Building Instructions
Airfoil
Wing area
Wing loading
Empty weight
: Symmetrical
: 1015 sq.in.
: 22-23 oz/sq.ft.
: 69 oz. (1950g)
Suggested Equipment:
(1) Hacker A50 16S
(1) Jeti Advance 70 Pro SB ESC
(1) TP5000 6S battery
(4) HS-7985MG servo
(1) TY 3" White spinner
(1) APC-E 16x10 propeller
(1) Deans connector
(1) 24" Servo extension
(1) 12" Servo extension
(2) 6" Servo extension
(2) Velcro strap (Esprit)
上一篇:【童愛模型】美國3dhs 41寸EDGE540,特價3550元
下一篇:【童愛模型】SECRAFT韓國精品~油管夾,每個90元
發表於 2013年7月22日 05:11 PM | 顯示全部樓層
夢寐以求的飛機~
發表於 2013年7月22日 05:35 PM | 顯示全部樓層
好讚的飛機啦.....引擎os50也不錯....
GMT+8, 2025年12月30日 01:52 AM
