查看: 1393|回復: 0
【童愛模型】美國3dhs 89寸AJ slick540,特價23400元
發表於 2013年7月21日 05:39 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年8月11日 10:02 PM 編輯
【童愛模型】美國3d hobby shop 89寸AJ slick540 ETOC比賽用機,性能和準度各方面都很完美,就連高手都夢寐以求想要嚐試,亞洲開賣了,機會難得
第一批預計8月15日到貨,橘色和紅色款各限量一台
搭配GP-61CC特價34500元
組裝說明書
http://www.3dhobbyshop.com/assets/images/3DH-89SLICK/3DH-89SLICK-MANUAL.pdf
http://www.3dhobbyshop.com/assets/images/3DH-DA50-INSTALLGUIDE.pdf        http://www.3dhobbyshop.com/assets/images/3DH-50CC-ELECTRONICS-GUIDE.pdf
89" Slick
The 89 Slick, designed by Andrew Jesky, is one of the largest 50CC aircraft in the world, and is remarkably light for its huge size. Larger than some 35% aircraft, the Slick delivers huge performance very similar in feel to a 40% aircraft. Pilots all over the USA love the anti-gravity 3D performance of their Slick, and appreciate the extreme precision of the AJ-designed aerodynamic package. This is the aircraft that will show your best piloting off to the world and make it all easy for you.
The 89 Slick features all important performance and durability features: 4-40 ball link hardware, pre-finished canopy and hatch, pre-finished motor box with aluminum bracing, carbon one-piece landing gear with aluminum-braced mount, pre-hinged wings and stabs, carbon wing and stab tubes, carbon wing and stab receiver tubes, carbon tailwheel, aluminum-hub wheels, genuine ultracote, wing bags, and stab bag.
Specs:
Winspan: 89"
Length: 91"
Wing Area: 1500 Sq. Inches
Weight 17-19 lbs.
Required Equipment
Engine:
DA-60
DA-50
DLE-55
Note: The 89" Slick firewall is set up for the DA-50 engine. This engine provides excellent performance and bolts on with stock 3" standoffs.
The DA-60 provides extreme performance with no weight penalty and is recommended. The DA-60 is NOT the same length as the DA-50 and does not mount the same way.
The 89" kit includes a generic fuel tank, but American-made Fourtitude fuel tanks are the best and are a recommended upgrade.
Electric Power System:
Hacker Q80-8M Motor - 24 x 10 prop
Castle Creations ICE HV160 ESC
12S 5000mah Lipo (Two 6S 5000mah running in series)
Servos:
QTY 5 Hitec HS-7955TG
Servo Arms:
QTY 1 SWB 4" Offset for Rudder
QTY 2 SWB 2" Single Sided for Elevators
QTY 2 SWB 1.5" Single Sided for Ailerons
Extensions:
QTY 2 52" For Elevators
QTY 2 20" For Ailerons
QTY 2 8" For Ailerons (Rx side)
QTY 1 20" For Throttle or ESC
QTY 1 12" For Rudder
Spinner:
4.0"
上一篇:【童愛模型】美國3dhs 84寸Bigfoot,特價17300元
下一篇:【童愛模型】美國3dhs 92寸EDGE540今年新機,特價24000元
GMT+8, 2025年12月31日 02:09 AM
