查看: 1864|回復: 5
【童愛模型】美國3dhs 84寸Bigfoot,特價17300元
發表於 2013年7月20日 11:56 PM | 顯示全部樓層 |閱讀模式
本帖最後由 cute969211 於 2013年9月11日 11:24 AM 編輯
【童愛模型】美國3d hobby shop 84寸Bigfoot
亞洲首賣,第一批預計8月15日到貨,黑色和紅色款各限量一台
搭配DLE-30特價23000元
組裝說明書
http://www.3dhobbyshop.com/assets/images/3DH-84BIGFOOT/Manual/3DH-84Bigfoot-MANUAL.pdf
Wingspan:
84" (2135mm)
Length:
69" (1750mm)
Weight:
12-14 lbs. (5450-6350g)
Channels:
4,5
Good: Hacker A60 6XS, 20x10
Better: Hacker A60 5S, 20x10
Engine: 30-35cc
TP3900 8S/TP6600 6S
75mm/3" spinner
The BigFoot is 3D Hobby Shop's first high-performance, high-wing airplane. This amazing model will perform any maneuver traditionally done by Alaskan and Canadian bush pilots with the rugged, light, highly maneuverable aircraft they fly. Bush-planes rely on light weight, large wings, high power, and big flaps to do these amazing things. Because these extreme capabilities are very similar to 3D flight, the BigFoot fits right in to our 3D Hobby Shop lineup of extremely high performance model airplanes. The BigFoot has an 84" (2135mm) in wingspan and its bush plane shape was inspired by the designs of several of these epic aircraft instead of being an exact scale model of any particular plane. Built of strong, lightweight balsa and ply construction and covered in genuine Ultracote; BigFoot is an impressive aircraft. Removable wing halves and carbon tube spar ensure easy transportation. The Bigfoot also includes functional wing struts and functional tail bracing. The landing gear is also an important part of any bush plane. The BigFoot uses a resilient aluminum main gear assembly that bounces back from big hits. Although the kit includes a conventional pavement wheel, we expect virtually everyone to choose a big, bouncy "Tundra" style tires for their airplane. Our recommendation is to use inflatable 6" (160mm) tires. The BigFoot has an extremely wide speed range, from fast to extremely slow.
In addition to the classic bush pilot maneuvers such as ultra-short takeoffs and landings, the brand new 3d Hobby Shop BigFoot is capable of a full suite of 3D maneuvers, including hovering, torque rolling, and rolling harrier flight. You will also enjoy how well the Bigfoot performs snap rolls, knife-edge flight, and many other maneuvers.
Special Features:
- Control surfaces: Ailerons, Elevator, Rudder and Flaps
- Fully illustrated, step-by-step instruction manual
- Complete hardware package
- Pre-painted aluminum landing gear
- Lightweight balsa/ply construction
- Pre-painted fiberglass cowl
- Removable two piece plug-in wings
- Covered in authentic UltraCote
- High contrast color scheme
Suggested Equipment:
(1) DLE-35cc RA gasoline engine
(1) XOAR PJA 20x8 propeller
(1) Hacker A60 5S
(1) Jeti Spin 99 Opto ESC
(1) TP3900 8S battery (4S + 4S)
(1) Jeti voltage regulator SBEC
(6) HS-7985MG servo
(1) HS-425BB servo (w/engine)
(1) TY 3" Black/Red spinner
(1) APC-E 20x10 propeller
(2) Deans connector
(1) Deans serial connector 2S
(2) 24" Servo extension
(2) 12" Servo extension
(2) 9" Servo extension
(4) 6" Servo extension
(2) 160mm Wheels large tundra or
(2) 6" Wheels large treaded lightweight
(4) Velcro strap (Esprit)
Suggested Equipment (6S):
(1) Hacker A60 6XS
(1) TP6600 6S battery
上一篇:XFC2013 TOC 3D花式1至7名比賽影片
下一篇:【童愛模型】美國3dhs 89寸AJ slick540,特價23400元
發表於 2013年7月21日 09:04 AM | 顯示全部樓層
發表於 2013年7月21日 05:33 PM | 顯示全部樓層
3D Hobby Shop的其他機種 您會進嗎 ????
Joe Smith - Good Job ~
發表於 2013年7月21日 06:06 PM | 顯示全部樓層
我要一台白紅色的。。。
 樓主| 發表於 2013年7月21日 06:16 PM | 顯示全部樓層
rzx135sp 發表於 2013年7月21日 05:33 PM
工廠目前有現貨的只有5款,今天會慢慢的上架
 樓主| 發表於 2013年7月21日 06:17 PM | 顯示全部樓層
ysh1606 發表於 2013年7月21日 06:06 PM
我要一台白紅色的。。。
好的貨到會通知,你排第一位
GMT+8, 2025年9月14日 02:53 AM
