查看: 5625|回復: 24
發表於 2013年7月16日 01:43 AM | 顯示全部樓層 |閱讀模式
本帖最後由 benyangsab700 於 2013年8月28日 04:19 AM 編輯
SAB義大利原廠於7月15號公布. GOBLIN 630與GOBLIN 700降價 (空機含SAB大小槳)
DescriptionComments
General Specifications
Electronic Specifications
  • Main rotor diameter: 1568mm (with 690mm blades)
  • Main blade length: 690 to 710mm
  • Tail rotor diameter: 296mm
  • Tail blade length: 115mm
  • Main shaft diameter: 12mm
  • Tail shaft diameter: 6mm
  • Spindle diameter: 10mm
Weight including  electronics 3470g (excluding batteries).
Maximum motor size: 64mm diameter, maximum height 64mm
Battery compartment: 60x58x350mm (adaptable to 64x58x350mm)
  • Main Motor: Up to 62mm diameter motor can be used
  • Maximum Battery Size: 60mm x 58mm x 350mm
  • Cyclic Servos: High torque servos highly recommended
  • Tail Servo: High speed, digital servo recommended
Ratio
  • 18T Pinion = ratio 11.3:1
  • 19T Pinion = ratio 10.7:1
  • 20T Pinion = ratio 10.2:1
  • 21T Pinion = ratio 9.7:1
  • 22T Pinion = ratio 9.3:1
  • 23T Pinion = ratio 8.9:1
  • 24T Pinion = ratio 8.5:1
  • 26T Pinion = ratio 7.8:1
With Scorpion motor HK LE 4525-520,
normal flight= 20T
Hard 3D= 21T
Package Includes:
Included:
(1) SAB Goblin 700 – Kit Only
(1) SAB 690mm Carbon Fiber Main Rotor Blade Set
(1) SAB 115mm Carbon Fiber Tail Rotor Set
What’s Needed for Flight:
(3) Cyclic Servos – High Torque Recommended
(1) Tail Servo
(1) Brushless Main Motor
(1) Brushless ESC
(2) 6S 22.2V LiPo Battery – 12S 44.4V System
(1) Flybarless Gyro
(1) 7+ Channel Transmitter
(1) 7+ Channel Receiver
(1) LiPo Battery Charger
Kit Notes:
SAB Goblin 700 comes as a kit form, requiring a complete build and all necessary electronics. Kit is designed for advanced pilots only.
Disclaimer: SAB Heli Division does not endorse any of the electronic components listed. These are only suggestions based on our own testing. Please make sure to do your own research to ensure compatibility between these components, specially between motors and ESCs.
Available Soon!!!
上一篇:Goblin 升級改裝品
下一篇:德國SpinBlades Red Tips. 沒用過我 別說你最好.
發表於 2013年7月16日 02:29 AM | 顯示全部樓層
本帖最後由 brian5488 於 2013年7月16日 02:30 AM 編輯
水哦,太棒了!看來原廠應該又有新機要上市了!
發表於 2013年7月16日 03:13 AM | 顯示全部樓層
brian5488 發表於 2013年7月16日 02:29 AM
一語提醒夢中人....
 樓主| 發表於 2013年7月16日 04:57 AM | 顯示全部樓層
是有聽說新機要上市.  但還需一段時間.  降價與新機無關.
下一台應該會是.............4字頭.  官方未公布.  可能還要一段時間.
發表於 2013年7月16日 08:10 AM | 顯示全部樓層
benyangsab700 發表於 2013年7月16日 04:57 AM
下一台應該會是.............4字頭.  官方未公布 ...
現在買700和630正是時候哦!還好500原廠這波沒降價,不然今天剛入手500的我會很幹!
發表於 2013年7月16日 09:46 AM | 顯示全部樓層
挖喔~~價錢好划算喔!!
GMT+8, 2025年12月30日 05:30 AM
