查看: 983|回復: 1
[x取消] [5900]全新 MultiWii 頂級專業飛控版 x2 + 藍芽 + 0SD
發表於 2013年7月9日 09:13 PM | 顯示全部樓層 |閱讀模式
本帖最後由 rctony 於 2013年9月29日 05:37 PM 編輯
全新品,僅拆開檢查.
(MultiWii PRO Flight Controller w/MTK GPS Module + Multiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560) V2.0 + 藍芽 + 0SD) 售$5900.
#不建議初學者購買,設定需要有一定多軸常識.
MultiWii PRO Flight Controller w/MTK GPS Module 諸元:
(MultiWii PRO)
• SMD component design with Atmega2560
• ITG3205 Triple Axis Gyro
• BMA180 Accelerometer
• BMP085 Barometer
• HMC5883L Magnetometer
• Servo output for camera pitch and roll control
• Supports direct connection of GPS module (MTK 3329 GPS module included)
• On-board USB connection for programming
(MTK 3329 GPS Module)
• Based on MediaTek Single Chip Architecture.
• L1 Frequency, C/A code, 66 channels
• High Sensitivity, Up to -165dBm tracking, providing superior urban performance
• DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
• USB/UART Interface
• Supports AGPS function (Offline mode: EPO valid up to 14 days)
Specs:
(MultiWii PRO)
Mounting: Standard Mk style mounting holes 45mm X 45mm
Dimensions: 70x50x12mm
Weight: 16g
(MTK 3329 GPS module)
Position Accuracy: < 3m CEP (50%) without SA (horizontal)
Cold Start: under 35 seconds (Typical)
Warm Start: under 34 seconds (Typical)
Hot Start: under 1 second (Typical)
Power Consumption: 48mA @ acquisition, 37mA @ tracking
Shut-down current consumption: 15uA, typical
Dimensions: 30x26x7mm
Weight: 8g
Multiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560) V2.0) 諸元:
• Supported MegaPirateNG and MultiWii firmware
• Up to 8-axis motor output
• 8 input channels for standard receiver
• 4 serial ports for debug/Bluetooth Module/OSD/GPS/telemetry
• 2 servos output for PITCH and ROLL gimbal system
• 1 servo output to trigger a camera button
• 6 Analog output for extend device
• A I2C port for extend sensor or device
• Separate 3.3V and 5V LDO voltage regulator
• ATMega 2560 Microcontroller
• MPU6050 6 axis gyro/accel with Motion Processing Unit
• HMC5883L 3-axis digital magnetometer
• MS5611-01BA01 highprecision altimeter
• FT232RQ USB-UART chip and Micro USB receptacle
• On board logic level converter
Flight mode for Multiwii:
• One of the following basic modes
– Acro
– Level
– Alt Hold
- Heading Lock
• Optional mode
– HeadFree (CareFree)
– GPS Hold (Need GPS receiver)
– GPS Back to home position (Need GPS receiver)
上一篇:誠徵 1:10 甩尾車或拉力車一套
下一篇:【誠租】卡斯特BEC設定卡,屏東
發表於 2013年7月29日 09:16 AM | 顯示全部樓層
頂……………………
GMT+8, 2025年12月31日 06:20 AM
