查看: 1667|回復: 1
PYRO 750-45 MOTOR 特價
發表於 2013年6月27日 08:15 AM | 顯示全部樓層 |閱讀模式
K27708 PYRO 750-45 MOTOR
由零售價
TWD 14,194
現售特價
TWD 13,469
http://www.ksmodel.com.hk/index.php?route=product/product&product_id=2066
上一篇:KONTRONIK 黑色馬達
下一篇:Kyle Dahl One World Champion
 樓主| 發表於 2013年6月27日 08:18 AM | 顯示全部樓層
450 RPM/V
max. 25000 RPM
453 g
> 4.5 kW
PYRO 750 – a star is born.
The PYRO 750 continues the heritage of the KONTRONIK PREMIUM LINE. It is compact, extremely powerful, and has a power output of 4.5KW. The PYRO 750 surges past the performance of the PYRO 700, approaching the levels previously set by the PYRO 800.
The unique design of the PYRO 750 provides a shaft with two sizes. The internal shaft is 8mm, allowing the use of 8mm bearings for longer life, and an external shaft of 6mm that allows it to easly fit most helicopters.
If you need ultimate power for a 700 class helicopter, look no further as the PYRO 750 is the new powerhouse for the 700 class.
Three different RPM Versions are available, providing you with the perfect choice for your model.
The PYRO in short:
Neodym magnets, heat resistent up to 150 degree C
Specialized wire, heat resisten up to 300 degree C
Perfectly balanced
Optimized metal sheets
Optimized ventilation
GMT+8, 2026年1月8日 04:07 AM
