查看: 1875|回復: 1
[680含運]2013 最新版 HOBBYWING 好盈三合一USB設定卡測電表
發表於 2013年4月28日 10:45 PM | 顯示全部樓層 |閱讀模式
本帖最後由 chiuchiyuan 於 2013年5月2日 01:08 AM 編輯
★RCGF★
2013 最新版 新包裝
舊版二合一已經停產
HOBBYWING 好盈三合一
USB無刷電變專業編程設定卡
多了測電錶功能
你的設定卡是不是常常用了一次就丟在旁邊,
這次好盈把測電錶功能加入,
讓你拿出去外場也可以使用,
設定卡不單單只是設定卡了!
Feature:Suitable for the following ESC:
    PLATINUM series helicopter/aircraft ESC
  • XERUN and EZRUN series Car ESC (Version 2.0 and 2.1)
  • XERUN-120A V3 ESC
(Note: To work with XERUN V3 ESC, the LCD Program Box MUST be updated by a new version USB Link Software, that is, the version not ealier than V3.0_Beta_120401)
Specification:
    Size: 91mm (L) * 54mm (W) * 18mm (H)
  • Weight: 65g
  • Input Voltage: 4.8-6V (If the ESC hasn’t a built-in BEC, you must use an additional battery pack to supply the program box)
  • Displayer: 16*2 characters LCD.
  • Interface: Mini USB interface, ESC interface (Futaba plug), Power supply interface (Futaba plug)
Programmable Items:A) The programmable items for the XERUN and EZRUN series car ESC:
    Running Mode
  • Drag Brake Force
  • Low Voltage Cut-Off Threshold
  • Start Mode
  • Maximum Brake Force
  • Maximum Reverse Force
  • Initial Brake Force
  • Throttle Neutral Range
  • Timing
  • Over-Heat Protection
  • Motor Rotation
  • Lipo Cells Amount
*Note: Some speed controllers have less programmable items, but some have more. Please read the user manual of your speed controller to get detail information.
B) The programmable items for the PLATINUM series airplane ESC:
    Brake
  • Battery Type
  • Low Voltage Protection Mode (Cutoff Mode)
  • Low Voltage Protection Threshold (Cutoff Threshold)
  • Start Mode
  • Timing
  • Governor Mode
  • Reserved Item #1
  • PWM Frequency
  • Built-In BEC Output
  • Reserved Item #2
  • Lipo Cells Amount
Include:
    Hobbywing 3 In 1 Professional Multifuction LCD Program Box (1 pc)
  • USB (1 pc)
  • Program Wire (2 pcs)
  • Manual (1 pc)
正品好盈三合一LCD 編程設定盒車船飛機鉑金全系列電調編程卡
多功能LCD專業編程設定盒可對好盈科技出品的無刷電調進行參數設定。其界面(LCD液晶屏幕)直觀友好,通過它可以輕鬆設置電調的所有參數。另外還可以通過其USB接口將電調和個人電腦相連,進行電調程序的在線更新及參數的精細設定。設定盒小巧便攜,非常適合在外場使用。
這款多功能專業編程設定盒適用於好盈科技有限公司生產的以下產品:
XERUN系列車模無刷電調(V2.0及更高版本)
EZRUN系列車模無刷電調(V2.0及更高版本)
PLATINUM系列 空模無刷電調
中文說明書下載地址:http://www.hobbywing.com/uploadf ... ual/HW-SM805-cn.pdf
USB LINK SOFTWARE程序說明書:http://www.hobbywing.com/uploadf ... nual/hw-20A-usb.pdf
  • 工作模式:
    1、 作為獨立設備設置電調參數: 直接利用自帶的LCD液晶顯示屏顯示電調參數,通過設定盒上的按鍵進行參數設定;
    2、 作為USB適配器連接電調和個人電腦:利用PC軟件實現電調程序更新和參數設定;
    3、 作為鋰電池電壓檢測器:測量鋰電池整組電壓和單體電壓;
    產品規格:
    1、 尺寸: 91mm(長)*51mm(寬)*17mm(厚)
    2、 重量: 65g
    3、 輸入電壓:4.5V—12.6V(僅當電調本身沒有BEC輸出時,才需要用單獨的電池組為設定盒供電)
    4、 接口類型:Mini USB, 電調接口(Futaba插座),電源接口(Futaba插座)
    和“二合一專業編程設定盒”的比較:
    1. 舊款名為2 IN 1 Professional LCD Program Box(即“二合一專業編程設定盒”,該產品已停產),新款名為Multifunction LCD Program Box(即“多功能LCD編程設定盒” ),它使用更大容量的微處理器MCU,並新增了鋰電電壓檢測功能)。
    2. “二合一專業編程設定盒”有兩類固件:一類固件只適用於XERUN-120A-V3.0及V3.1電調而不支持其它電調,這類固件名稱一定帶有“_V3”後綴,如“V1.11_120331_V3”;另一類固件則不支持XERUN-120A-V3.0及V3.1電調,而支持PLATINUM系列飛機電調、EZRUN V2.0及XERUN-V2. 0及V2.1系列車用電調,這類固件的名稱不帶“_V3”後綴,如“V1.08_120504”。請根據電調類型正確選擇二合一LCD專業設定盒的固件。
    (注:出廠時,其默認固件不是V3固件,客戶可自行升級到V3固件,亦可以重新降為舊固件)
    而“多功能LCD專業設定盒”則採用了更大容量的MCU,單一固件版本即可支持多種電調,如:PLATINUM 系列飛機電調、EZRUN V2.0及XERUN-V2.0、V2 .1、V3.0、V3.1等車用電調,使用時無需頻繁更換設定盒固件,因此更為簡便。
上一篇:此帖已經結束 無貨謝謝
下一篇:[180含運]螺旋槳平衡器 磁浮 碳纖版 / 四旋翼 / 多軸 / FPV
 樓主| 發表於 2013年4月28日 10:50 PM | 顯示全部樓層
二合一的價錢買三合一的新   第一批熱騰騰 拿到的數量不多 速度~
GMT+8, 2025年10月29日 01:43 PM
