上一篇:[8900元] MT4-G3 1/8 大腳車下一篇:CEN Aqua Jet 的16級手拉引擎| 本帖最後由 rctony 於 2013年11月6日 09:40 PM 編輯
 德國 Schulze頂級充電器 next 10.36-12 Car (95新,有含溫控線,已升級至官網最新版韌體,無平衡線), 當時國外購入$28000. (交換物品  遙控車, 摺疊腳踏車, iPhone4S, iPAD2, mini iPAD, note 10.1, GOPRO 3 ,如要購買價錢好談~! 0929-587-789
 規格如下:
 NextGeneration type
 next 10.36-12
 Weight about        830 g
 850 g
 Size (w / d / h) about        160*180*67 mm
 Colour of the case        anthracite
 Internal fan        12 V / 7 W /
 55 dBa
 Serial port (included)        5 V SIO
 Optional available in-/outputs        included
 USB + temperature sensor + blinking light + fan
 Supply voltage range        10.0 - 15.0 V
 Under voltage warning        11.6 - 10.4 V
 - adjusting range
 Under voltage warning        0.5 V
 - cut off below warning
 Supply current up to (about)        25 A
 Quiescent current about ...        100 mA
 + current LCD-illumin. (disconnectable, about)        50 mA
 Trickle charge currents Ni-Cd        Trickle pulses
 Trickle charge currents other battery types        no
 Adjustable Lithium voltages        yes
 (for full / empty)
 Password protected owners name        yes
 User setted charge/discharge configurations        yes
 Battery 1 Output - Charge circuit        next 10.36-8
 Number of voltage measuring inputs        8
 Ni-Cd / Ni-MH-batteries
 cell-count @ 1.65V        1*-36 cells
 (Nickel-cell)
 max. battery capacity Ni-Cd        0.1 - 5.0 Ah
 max. battery capacity Ni-MH        0.1 - 10.0 Ah
 Lead / Li-Fe / Li-Io / Li-Po batteries
 Number of balancing inputs/outputs        8
 12
 Max. balancing current        1:00 AM
 Number of Li-Po cells        14 cells
 Number of Li-Io cells        14 cells
 Number of Li-Fe cells        16 cells
 Number of Lead cells        23 cells
 Max. battery capacity in mAh        0.1 - unlimited
 Charge power        next 10.36-8
 @ charge voltages
 next 10.36-12
 Charge power @ 12V        240 W
 car battery voltage about
 Charge current @ 1-24V        10.0 A
 (~1-15 Ni-/~1-6Li-cells) about
 Charge current @ 30V        8.0 A
 (~18 Ni-/~7 Li-cells) about
 Charge current @ 40V        6.0 A
 (~24 Ni-/~9 Li-cells) about
 Charge current @ 45V        5.3 A
 (~27 Ni-/~11 Li-cells) about
 Charge current @ 50V        4.8 A
 (~30 Ni-/~12-Li-cells) about
 Charge current @ 60V        4.0 A
 (~36 Ni-/~14 Li-cells) about
 Battery 1 output        next 10.36-8
 - discharge circuit
 next 10.36-12
 Cell count (@ 1.30 V/Ni- /        1-40 Ni-cells
 4,00 V/Li-cell)        1-14 Li-cells
 Discharge power about        240 W
 @ 12 V car battery voltage
 Discharge current @ 1-24 V        10.0 A
 (~1-18 Ni-/~1-6 Li-cells) about
 Discharge current @ 32 V        7.5 A
 (~24 Ni-/~8 Li-cells) about
 Discharge current @ 36 V        6.7 A
 (~27 Ni-/9 Li-cells) about
 Discharge current @ 40 V        6.0 A
 (~30 Ni-/~10 Li-cells) about
 Discharge current @ 49 V        4.9 A
 (~36 Ni-/~12 Li-cells) about
 Discharge current @ 54 V        4.4 A
 (~40 Ni-/~14 Li-cells) about
 Max. discharge power when connected to a fully charged car battery or to an AC/DC power supply        100 W
 Battery 2 output - charge circuit
 next 10.36-12
 Ni-Cd / Ni-MH batteries
 cell count (@ 1.65V / cell)        1*-6 cells
 Charge current ~        0.1 - 5 A
 Charge power @ 13,8 V car batt. & 12V output 2 about        60 W
 Max. battery capacity Ni-Cd        0.1 - 2.5 Ah
 Max. battery capacity Ni-MH        0.1 - 5.0 Ah
 Number of balancing inputs/outputs        0
 Li-Po cell count        1 - 2/3**cells
 Li-Io cell count        1 - 2/3**cells
 Li-Fe cell count        1 - 3 cells
 Lead cell count        1 - 4/5** cells
 Max. capacity mAh        0.1 - unlimited
