查看: 3198|回復: 8
Mini Vbar 5.3exp TWD6728-
發表於 2013年3月23日 09:07 AM | 顯示全部樓層 |閱讀模式
四月一號開始 New Mini Vbar 5.3exp (三獨立傳感器)
TWD6728-
Mini VBar "Blueline" 5.3 Express
The Mini VBar is the world’s smallest and lightest 3-axis virtual flybar system. It is designed to fit most electric helicopters. Despite its small size, the Mini VBar is equipped with top-quality sensors and will thus satisfy the highest performance expectations. Programming is done via a control panel, or via USB using the PC software. A special feature of the Mini VBar is the option to use it in conjunction with one or two 2.4 GHz satellite receivers (you may choose from various brands). This feature renders it unnecessary to use a primary receiver. It is also possible to connect the Mini VBar to a receiver in the conventional way.
MiniVBar operates with the following satellite receivers: Spektrum, Fasst, Jeti Duplex.
The all new Mini V-Bar can now be used in all electric model helicopters with only a few limitations: Do not use the Mini V-Bar in the following types of helicopters:
- Scale helicopters
- Helicopters with multi-bladed rotorheads (3+ blades)
- Custom built helicopters.
3-Axis Gyro System
Dimensions: 28 x 37 x 13 mm
Weight: 11 g
Content of MinVBar set: Mini VBar with 5.3 Express-Firmware and PC-Software Version 5.3, USB cable
(satellite receivers and control panel are not included)
LOGO 550SX上市了
LOGO 600 SX MINI VBAR, PYRO700-52
發表於 2013年3月23日 09:22 AM | 顯示全部樓層
真的是晚買有折扣...
發表於 2013年3月23日 08:15 PM 來自手機 | 顯示全部樓層
請問這樣昇級Pro是99美金還是45美金?
 樓主| 發表於 2013年3月26日 02:13 PM | 顯示全部樓層
新價格四月一號開售,升級一樣USD45-
 樓主| 發表於 2013年4月2日 03:36 PM | 顯示全部樓層
MIK4357 迷你 V-BAR 無副翼三軸陀螺儀 V 5.3快速版
http://www.ksmodel.com.hk/index. ... t&product_id=51
 樓主| 發表於 2013年4月5日 09:53 AM | 顯示全部樓層
順豐包運
GMT+8, 2026年3月6日 06:24 PM
