查看: 1399|回復: 0
Pyro 750-45到貨
發表於 2013年2月27日 03:25 PM | 顯示全部樓層 |閱讀模式
Pyro 750-45到貨
TWD 12,558-
PYRO 750 – a star is born.
The PYRO 750 continues the heritage of the KONTRONIK PREMIUM LINE. It is compact, extremely powerful, and has a power output of 4.5KW. The PYRO 750 surges past the performance of the PYRO 700, approaching the levels previously set by the PYRO 800.
The unique design of the PYRO 750 provides a shaft with two sizes. The internal shaft is 8mm, allowing the use of 8mm bearings for longer life, and an external shaft of 6mm that allows it to easly fit most helicopters.
If you need ultimate power for a 700 class helicopter, look no further as the PYRO 750 is the new powerhouse for the 700 class.
Three different RPM Versions are available, providing you with the perfect choice for your model.
The PYRO in short:
Neodym magnets, heat resistent up to 150 degree C
Specialized wire, heat resisten up to 300 degree C
Perfectly balanced
Optimized metal sheets
Optimized ventilation
上一篇:LOGO700 XXTREME套裝 Pro+
下一篇:Kontronik 160HV Cool Kosmik到貨
GMT+8, 2025年11月26日 09:07 PM
