查看: 7941|回復: 50
這算攀岩車嗎?
發表於 2013年1月31日 09:47 AM | 顯示全部樓層 |閱讀模式
發表於 2013年1月31日 10:48 AM | 顯示全部樓層
這個讚哦!
發表於 2013年1月31日 11:06 AM | 顯示全部樓層
性能有毒,外觀免疫.
發表於 2013年1月31日 12:15 PM | 顯示全部樓層
真帥........................................
發表於 2013年1月31日 12:23 PM | 顯示全部樓層
官網連結:
http://www.vaterrarc.com刪/Products/Default.aspx?ProdId=VTR03000
http://www.bigsquidrc.com刪/vaterr ... 1-9-rock-racer-rtr/
附上規格表
One of the most intriguing new products from Vaterra is their new 10th scale rock racer called the Twin Hammers RTR. The Twin Hammers doesn’t look like a crawler with tall gearing, it looks like a cross between a crawler and a full speed scale off-road buggy. Some of its features and specifications include-
* Everything you need is included in the box
* Shift-on-the-fly, two speed transmission
* Independent cantilever front suspension
* Brushless-ready drivetrain
* Waterproof electronics (see manual for more details)
* Spektrum™ DX3E 2.4GHz 3-channel radio system
* Scale lights, cockpit and body panels
* Dynamite® brushed Tazer™ 540 12-turn system with programmable modes included
* 12mm wheel hexes
* Dynamite 2S 7.4V 2000mAh Li-Po battery
* Dual-position battery tray for use with the optional Dynamite battery
* Beadlock wheels with Race Claw 1.9 scale tires
* Molded chassis and multi-piece roll cage
* 4-link suspension
* Adjustable, oil-filled, aluminum, coil-over shocks
* Comes with 1.8 amp Lipo wall charger
* Diffs- Front Gear Diff, Rear Locker
* Final drive ratio- Low: 32:1 High 18:1
* Interal gear ratio- Low: 4.05:1 High: 2.27:1
* 48 pitch gears
* Front and rear track- 9.75 in (247.7mm)
* Ground clearance- 0.91 in (23mm)
* Height- 6.125 in (155.6mm)
* Length- 18 in (457.2mm)
* Tire diameter- 4.1 in (104.14mm)
* Wheel diameter- 2.25″ overall, 1.9″ bead surface
* Wheel width- 0.75 in (19.05mm)
* Weight- 2.12 lbs (0.96Kg)
* Wheelbase- 11.6 in (294.6mm)
* Width- 5.9 in (149.9mm)
寬度跟長度都可以....
還有無刷跟二段變速~~
但國內冷門`解毒一半
[ 本帖最後由 austin0902 於 2013年1月31日 12:29 PM 編輯 ]
發表於 2013年1月31日 01:38 PM | 顯示全部樓層
應該是HORINON旗下子公司的產品
官網:http://www.horizonhobby.com/products/twin-hammers-1-9-rock-racer-rtr-VTR03000
RTR付S牌中低階3動遙控電池充電器
價格應該滿親民的
聽說本地代理商正在洽辦中
依該代理商的習性,備料應該會很充足
毒癮正在發酵中
[ 本帖最後由 dllee 於 2013年1月31日 01:47 PM 編輯 ]
GMT+8, 2025年12月31日 02:59 AM
