查看: 1650|回復: 9
[完成] (飛友預購中)全新未組裝HOBBY KING 搶手貨微型四軸套件一組
發表於 2012年5月14日 10:58 AM | 顯示全部樓層 |閱讀模式
全新未組裝HOBBY KING 搶手貨微型四軸套件一組當初買了三組...拿一組出來賣
HOBBY KING 搶手貨微型四軸套件一組///本月初購入3000含運//不拆賣
整合式微型四軸機架
Turnigy Integrated PCB Micro-Quad (KIT) x 1
微型外轉無刷2900KV/含完整配件
Turnigy 1811 brushless Outrunner 2900kv x 4 組
6A微型無刷電子調速器/含BEC
TURNIGY Plush 6A /.8bec/6g Speed Controller x 4 組
詳細規格如官網介紹(請自行修改連結將rctw.net改為hobbyking.com)
http://www.rctw.net/hobbyking/store/uh_viewItem.asp?idProduct=22607
This tiny yet brilliantly designed Micro-Quad features an integrated PCB frame, Simply bolt on the motors then solder your choice of 6amp ESC directly to the frame!
An integrated power distribution system is also included making for one of the neatest electronics installs around. All mounting hardware and frame components are included in the kit. All you will require to have this little monster in the air is four Turnigy T1811-2900kv motors, four 6Amp ESCs, a set of 5x3 Micro-quad props (2 Clock wise and 2 counter clockwise) an 800mah 2s 7.4v Lipoly battery, a HobbyKing Multi-rotor control board and your own transmitter and receiver (Tx/Rx).
Features:
Light weight design.
Integrated PCB for component installation.
Included a full set of frame and mounting hardware.
Specs:
Flying Weight: 145g (not including RX and battery)
Width: 250mm
Height: 85mm
Required:
4 x Turnigy T1811-2900kv
4 x 6Amp ESC
4 x 5x3 Prop (2CW & 2CCW)
1 x HobbyKing Multi-Rotor Control Board
1 x 800Mah 2s 7.4v Lipoly battery
16 x M2x8 Bolts (for motor)
16 x M2 lock nuts (for motor)
Your own radio and 4 channel receiver.
http://www.rctw.net/hobbyking/store/uh_viewItem.asp?idProduct=8142
Dimension: 23mm x 18mm, 31mm(with shaft)
Weight:
12g  (kv2900) (not including connectors)
Diameter of shaft:F2mm
Length of front shaft:
F8mm
Lamination thickness: .
2mm
Magnet type: 45SH
Voltage:
7.4V
Amp:
5.8A
Thrust: 165g
Propeller: 6030
http://www.rctw.net/hobbyking/store/uh_viewItem.asp?idProduct=4318
Plush 6amp Brushless Speed Controller
Model: Plush 6A
Continuous Current: 6A
Burst: 8A
BEC: Linear
BEC Output: 5v/.8A
Lipo Count: 2cell Guarenteed (3 cell capable but not warranted)
NiMH: 5-6
Programability: Programming card or Radio Controller
Weight: 6g
[ 本帖最後由 ccw590501 於 2012年5月16日 08:41 AM 編輯 ]
上一篇:徵天蠍星Scorpion HK-3026-1600KV
下一篇:出售600N(軸傳)一枚..詳儒內容
發表於 2012年5月14日 11:09 AM | 顯示全部樓層
這個有含飛控板嗎?..............
 樓主| 發表於 2012年5月14日 11:20 AM | 顯示全部樓層
原帖由 hsu32 於 2012年5月14日 11:09 AM 發表
你好..不含飛控板
視個人需求市面上的飛控板都可搭配使用
發表於 2012年5月14日 12:00 PM | 顯示全部樓層
推推推~~~~~~~~~
好有質感
 樓主| 發表於 2012年5月14日 04:39 PM | 顯示全部樓層
原帖由 yingdavid 於 2012年5月14日 12:00 PM 發表
推推推~~~~~~~~~
好有質感
就是這樣才會不小新買太多啦.........感謝幫推
發表於 2012年5月15日 08:11 AM | 顯示全部樓層
幫你踢一下!!上去!!
才剛買450四軸不然預算購就來買台比較小的!!
GMT+8, 2025年12月26日 04:18 AM
