查看: 10119|回復: 44
SAB 總代理已正式代理MINICOPTER DIABOLO
發表於 2012年5月12日 09:42 PM | 顯示全部樓層 |閱讀模式
恭喜阿BEN.  SAB台灣總代理取得MINICOPTER DIABOLO(空中陀螺)代理.
今已購入10台DIABOLO來台.  預計7-10天後彽達.
這次連備料同步彽台....請無需煩惱備料問題.
現推出預售優惠案: $38500
DIABOLO ( 空中陀螺 ) 空機一台 (德制)
加贈一組MATT BLACK SPIN BLADE 主槳一副 (市價$4500 德制)
DIABOLO是台純德制機.
與TDR相像......但PERFORMANCE(操控)決對凌駕TDR之上....衝場....暴力3D都難不倒它.....
Diabolo
The storyAs promised, the supply of spare parts of the first Joker continued until the end of 2010. These first mechanics still enjoys great popularity. Over time, many requests were brought to my attention, to create a modernized mechanics of the Joker 1. The concept of two-stage gear transmission with belt-driven tail has proved to be extremely reliable. So it made sense, parallel to the Joker 3 to create a special 3D helicopter, of which the performance will be greater than that of the Joker.
The construction began quietly in the spring of 2010. It is often better to work on a special project like this when not so many people know about it. So some very intensive testing was possible for several months, during which many small changes have been included into the design. Such a new model requires a testing period, during which improvements can be made systematically.
Why "Diabolo"?A diabolo is a toy with which you can show tricks after some practice, like a 3D heli. A diabolo is however also a rifle-bullet for target shooting, which can be equated with speed flying. When the first canopy was completed, a friend was present at the model aircraft field and he has a spontaneous declared a third meaning when he looked at this new design: "That's the devil!" Anyone who looks at the canopy closely will certainly discover what he means. This detail is to prevent tearing of the canopy in the area of the aileron servos from frequent removal. This newly designed shape still matches the Joker family perfectly! However, it is clearly a few inches higher, and a bit narrower, making it much more aerodynamic in flight.
FlightperformanceWhen you see the model fly for the first time as an experienced pilot, the thick tail boom immediately catches your eye. This allows it to be seen at great distances or during fast maneuvers extremely well, and gives the diabolo almost the appearance of a model with a fuselage. Through the very light tail design and with a belt drive, very high pirouette rates are achieved. Most striking however is the enormous flexibility of the Diabolo. It can be flown with a slow turning main rotor, or flown with a very high rotor speed at the maximum limits.
Technical data
  • Rotor diameter: 1,56 to 1,68m (Blade length:690-750mm)
  • Weight with 12s/5000: 4,8-5,2 kg
  • 2-stage gear, helical spur gear
  • Gear ratio 1st stage: 1:3,1 to 1:4,13
  • Gear ratio 2nd stage: 1: 3,17
  • Belt driven tail rotor
  • Tail gear ratio 1,5:1
  • Tail rotor diameter: 290-300 mm
  • Length with canopy: 1,38 m
  • Length without canopy: 1,27 m
  • Height: 39 cm
  • Landing gear width: 22 cm
  • Tail boom diameter: 30 mm
  • Hanging battery for COG
  • Battery tray: 68(74)mm high, 64 mm width
  • Automatic belt tension over oil-pressure shock absorbers with adjustable spring rate
Pinion calculation: It is very difficult to find as manufacturer the best pinion for a customer, because there are many factors we do not know. A good calculator to find the individually best pinion you find here: Pinion calculator
[/media]
[/media]
[ 本帖最後由 benyangsab700 於 2012年5月12日 09:57 PM 編輯 ]
上一篇:蛇~~之-大補帖...之一
下一篇:Goblin休長假去了......................
發表於 2012年5月13日 12:56 PM | 顯示全部樓層
這不是好東西沒看到!沒看到!我什麼都沒看到拜託阿ben你把價錢提高個兩萬好嗎?這樣小惡魔就不會半夜一直來找我,很煩耶...
發表於 2012年5月13日 07:34 PM | 顯示全部樓層
教授大
您心中深處早已住一隻大惡魔,這隻小惡魔算不上什麼
 樓主| 發表於 2012年5月14日 06:42 PM | 顯示全部樓層
對了......忘了說......凡是SAB會員...可享有5%的新機種的優惠.....
$38500
5% OFF = $36575 (含MATT BLACK SPIN BLADE 主槳)
發表於 2012年5月14日 08:14 PM | 顯示全部樓層
回復 4樓 benyangsab700 的帖子
妖壽 !
我的電話已經換了,不要再連絡了
我要專心等我的 " 女妖 "
 樓主| 發表於 2012年5月15日 01:59 AM | 顯示全部樓層
原帖由 ting21 於 2012年5月14日 08:14 PM 發表
妖壽 !
我的電話已經換了,不要再連絡了
我要專心等我的 " 女妖 "
賣假了ㄚ........過兩天你就打電話來了.......等你喔......
GetAttachment.jpg 我知道你喜歡紅色的殼.....
GMT+8, 2025年12月25日 11:52 PM
