搞了兩天
終於搞定了
老外有解決方法
我分享出來跟Windows Vista一樣
fms_win7.zip
(171.02 KB, 下載次數: 2820)
Windows 2000 or earlier
- download fms2alpha85.exe from http://n.ethz.ch/~mmoeller/fms/index_e.html
- install program fms2alpha85.exe
- optional, but recommended: download and install more models and landscapes from the
internet. Search the links at http://n.ethz.ch/~mmoeller/fms/index_e.html
and search Google.
Windows XP
- unzip and copy fms.bat and fms-ecomport-fix.reg to the "c:\program files\fms" directory
- change desktop link (right click - properties) to point to fms.bat instead of fms.exe
and search Google.
Windows Vista or later 32 bit (untested) should be the same as Windows XP but add
- unzip and copy d3drm.dll to the "c:\program files\fms" directory
Windows Vista or later 64 bit (untested)?
- install program fms2alpha85.exe (as administrator?)
- unzip and copy fms-vista.bat, fms-ecomport-fix.reg, and d3drm.dll to the
"c:\program files (x86)\fms" directory
- set properties of "c:\program files (x86)\fms\fms.exe" to Windows XP SP2 compatibility?
- change desktop link (right click - properties) to run fms-vista.bat instead of fms.exe
and search Google.
Notes
This d3drm.dll matches the one on a valid Windows XP SP3 machine. If you have access
to an older Windows machine (say XP or 2000), just get a copy of d3drm.dll from
c:\windows\system32. Searches on the internet show several different versions that all
have the same file size and version number as viewed from properties, but they are
different internally. They all scanned clean, but it still makes me wonder why they
have the same version number if they are different internally at all?
On 32 bit Vista (or later) that d3drm.dll should work if placed in either
"c:\program files\fms" or in "c:\windows\system32"
On 64 bit Vista (or later) that d3drm.dll should work if placed in either
"c:\program files (x86)\fms" or in "c:\windows\syswow64"
[ 本帖最後由 rest 於 2012年4月12日 04:05 PM 編輯 ] |
