查看: 1569|回復: 0
JETI BOX Profi 無線雙模式雙向編程器上市
發表於 2012年3月2日 07:26 AM | 顯示全部樓層 |閱讀模式
The JETIBOX profi is a mobile wireless device, offering maximum comfort to the user when viewing, processing and storing telemetric data. An integral part of the JETIBOXu profi is the system JETI DUPLEX 2.4GHz, which can be alternatively operated in one of the two offered wireless modes.
In mode Transmitter Module the JETIBOX profi can be operated with the transmitter as direct replacement of the exchangeable transmitter module.
In mode Monitor the JETIBOX profi is processing telemetric data, which are sent between transmitter and receiver of the JETI DUPLEX system. The telemetric data received from the model can be displayed on the monitor and simultaneously stored in the internal memory for later analysis.
    Two wireless modes
    Digital data transfer in the 2,4GHz (100mW)band
    Integrated antenna
    Compatible with Duplex and Duplex EX systems
    Internal memory 2GB
    Storing of telemetry in internal memory
    Detailed analysis of telemetric data
    Graphical telemetry presentation in form of graphs and bargraphs
    Graphical LCD-display 128x64 with background lighing
    Audible loudspeaker for acoustic signals
    Earphone output
    Replay of own sounds
    Storing of JETIBOX profi set-ups in user profiles
    Connection possibility to a PC via USB
    Telemetry processing on PC with the aid of the Flightmonitor program
    Firmware upgrade support by the user
    Low current consumption in stand-by mode
    BMS (Battery Management System)
    Charging via USB
JETI BOX Profi 說明書下載
上一篇:JETI Model Anti Spark 4.0mm & 5.5mm 防火花插頭上市
下一篇:像"鼎騏"這樣的廠商給一個"讚"
GMT+8, 2026年1月1日 03:12 AM
