查看: 833|回復: 0
【童愛店舖】 美國Desert Aircraft DA-170cc汽油引擎 ,特價62700元
發表於 2011年7月10日 11:01 PM | 顯示全部樓層 |閱讀模式
歡迎飛友訂購不含排氣管,可加購原廠DA-170排氣管6700元
原廠保固三年
DA 170說明書http://www.troybuiltmodels.com/ns/manuals/DA-170.pdf
  • Three crank bearings, long spacing between front bearings.
  • Four petal reed valve, bottom induction.
  • Desert Aircraft, auto advance, electronic ignition.
  • Walbro Carburator
  • Exclusive Desert Aircraft designed cylinders, pistons, and crankshaft.
  • CNC milled, 7075 aluminum alloy crankcase.
  • Low vibration.
  • Most torque in its class.
  • Long rod to stroke ratio.
  • Aerobatic power curve.
  • DA engines are designed using the latest tools and techniques, including 3D CAD and Stereo Lithography.
  • Displacement:10.48 ci (171.8 cc)
    Output:18 hp
    Weight:7.62 lbs (3.46 kilos)
    Bore:2.0472 in (52 mm)
    Stroke:1.594 in (40.49 mm)
    Length:7.67 in (195 mm)
    RPM Range:1,000 to 6,500
    RPM Max:9,200
    Fuel Consumption:4 oz/min @ 6,000 RPM
    Warranty:Three Year
  • The new benchmark for 40% aerobatic planes !
    With the experience of the extremely reliable DA-150 in our mind, we created the all-new DA-170. Even lighter, even stronger and the same reliability as the 150: The new champion for your 40% airplane.
    Recommended Props:
    2-Blades
    32x12
    32x10
    3-Blades
    29x12n
    28.5x12
[ 本帖最後由 cute969211 於 2011年7月10日 11:26 PM 編輯 ]
上一篇:【童愛店舖】 美國Desert Aircraft DA-50cc汽油引擎 ,特價20300元
下一篇:【童愛店舖】 美國Desert Aircraft DA-85cc汽油引擎 ,特價29500元
GMT+8, 2025年12月31日 07:56 AM
