查看: 5225|回復: 11
【童愛店舖】 美國Desert Aircraft DA-60cc汽油引擎 ,特價24000元
發表於 2011年7月9日 12:03 AM | 顯示全部樓層 |閱讀模式
首批進了五顆DA-60,7月19日到貨,已售出三顆,歡迎飛友訂購不含排氣管,可加購原廠DA-60排氣管3150元
原廠保固三年.
DA 60說明書http://www.troybuiltmodels.com/ns/manuals/DA-60.pdf
DA 60 Single
The DA-60 is the latest high performance offering from Desert Aircraft for planes in the 50cc to 70cc class. At only 1410 g (3.1 lbs), the power to weight ratio is excellent.
The DA reed valve and Walbro carburetor are well matched, providing consistent engine performance at all flight attitudes and throttle settings. Throttle and choke arms are pre-installed.
The engine delivers superb performance while maintaining excellent structural integrity. The rigid integral engine mount and robust, well balanced crankshaft ensure smooth operation. Depending on firewall location, the engine can be mounted without stand offs or spacers, which further eliminates vibration.
The DA-60 with its integral mount weighs less than the DA-50R with standoff mounts, and shows lower vibration levels than the DA-50R. With equal props, the DA-60 out turns the DA-50R by 600+ rpm!
The crankcase is CNC machined from 7075 T6 alloy, while titanium is used for the prop shaft extension.
The exhaust port shape lends itself well to standard style mufflers or tuned exhaust systems that use round headers. This is the same cylinder and piston as used on the well proven DA-120 twin.
As with all DA engines, each DA-60 is thoroughly test ran at the factory before shipping. The best service and support in the industry!
Specifications:
Displacement: 60.5 cc (3.7 c.i.)
Weight: 1410 g (3.1 lbs)
including Ignition: 1517 g (3.34 lbs)
Typical RPM Range: 1200 - 7500 1/min
RPM Max: 9500 1/min
Propellers:
Menz 2-Blade: 22x10", 22x12", 23x8", 23x10", 24x8", 24x10"
Super Silence Carbon 2-Blade: 23x12", 24x10", 24x12"
Super Silence Carbon 3-Blade: 22x10", 22x12"
有興趣者,歡迎與我連絡0912-278833施先生
[/media] DA.jpg
[ 本帖最後由 cute969211 於 2011年7月10日 11:15 AM 編輯 ]
上一篇:【童愛店舖】 金翼GW Ultimate 50CC C塗裝,特價12500元
下一篇:【童愛店舖】 美國Desert Aircraft DA-120cc汽油引擎 ,特價44000元
發表於 2011年7月9日 04:47 AM | 顯示全部樓層
回復 1樓 cute969211 的帖子
頭香~~~ DA品質~~讚啦! 首批數量不多歐~~
應該是說剩2顆可訂! 喜歡爆力3D的飛友腳手要緊喲!
發表於 2011年7月9日 09:27 AM | 顯示全部樓層
原帖由 ricky6811 於 2011年7月9日 04:47 AM 發表
有人在搥胸頓足 猶疑不決不知如何是好呀
明明真愛 又在~~~~~~~~~~~~~~~~~~~~
發表於 2011年7月9日 11:36 AM | 顯示全部樓層
原帖由 二林阿德 於 2011年7月9日 09:27 AM 發表
有人在搥胸頓足 猶疑不決不知如何是好呀
你............
發表於 2011年7月9日 12:22 PM | 顯示全部樓層
回復 3樓 二林阿德 的帖子
引擎中於要來了,等好久了
發表於 2011年7月9日 12:46 PM | 顯示全部樓層
原帖由 上原 於 2011年7月9日 12:22 PM 發表
引擎中於要來了,等好久了
對呀要等好~~~~久 我看2棵全要給它~~~~~~~
到時候要來呀~~~來呀~~~來拿呀
GMT+8, 2025年12月31日 11:10 AM
