查看: 3751|回復: 14
5/15 哈比王訂單
發表於 2011年6月16日 12:21 AM | 顯示全部樓層 |閱讀模式
怕大家沒看到,我這邊也發一次
這次訂了滿滿兩個訂單才消化完,可惜陳老大的需求排不進去,下次在幫陳老大買,本來只是要買些小東西,沒想到....我又買破表...因為我買了之前缺貨了車用6S電變,跟2.45m的無動力滑翔機準備改動力......
[ 本帖最後由 yada2222 於 2011年6月16日 12:22 AM 編輯 ]
上一篇:K牌 190組機文兼蓋大樓
下一篇:Hyperion JU-87
發表於 2011年6月16日 12:32 AM | 顯示全部樓層
好~~~~~~好~~~~~好多錢錢
發表於 2011年6月16日 12:40 AM | 顯示全部樓層
福德再次展現敗家實力!
 樓主| 發表於 2011年6月16日 12:53 AM | 顯示全部樓層
唉,都是你們買的數量很尷尬,一車裝不下,兩車又剩下太多空間,所以我買了這台
Be the envy of the scale glider fraternity at your local club with the H101-Salto aerobatic glider! Salto, meaning 「loop」 or more literally 「backward somersault」 in German, will have onlookers doing back flips once they see the scale finish and attention to detail of the large pilot and cockpit. Designed and built in the 70s only a small amount of these gliders ever went into production. Now you have the chance to own a piece of glider history.
Featuring sleek elegant lines and a V-Tail design, you will be able to test your skills and push the outer limits of aerobatic gliding. The glider features a fixed landing pre-installed in the fiberglass fuselage and ply/balsa built up wings with an easy sprung wing retention system that will have you performing a 「Salto」 in no time.
With large working flaps this model can be flown and landed in relatively small areas, plus, the model can be setup in a traditional flap/aileron configuration or a Quadro-flap configuration for extra control and breaking effect.
You will need 4 slim wing servos, 2 for each wing and Two standard servos, one for each surface of the v-tail. You will also require a transmitter and receiver (Tx/Rx) and battery.
Specifications:
Wing Span: 2.45 m (96.5")
Length: 1050mm
Wing Area: 30 dm2 (465 sq. in.)
Wing Airfoil: HN 805
Wing Loading: 46 g/dm2 (15 oz/sq. ft.)
Flying Weight: 1.4 kg (50 oz)
Required:
4 x Slim Wing Servo
2 x Standard servo
Rx and Tx with receiver battery
發表於 2011年6月16日 01:02 AM | 顯示全部樓層
http://tracking.post.japanpost.j ... 388JP&locale=en
我的敗家品,也在路上了!
 樓主| 發表於 2011年6月16日 01:25 AM | 顯示全部樓層
原帖由 ericraidmax 於 2011年6月16日 01:02 AM 發表
http://tracking.post.japanpost.jp/service/singleSearch.do?searchKind=S004&reqCodeNo1=EJ102721388JP&locale=en
我的敗家品,也在路上了!
你又買了什麼?海波浪JU87 ?
GMT+8, 2025年12月30日 08:23 PM
