查看: 565|回復: 2
[電子設備] 售~ Schulze頂級充電器 next 10.36-12 Car
發表於 2011年4月23日 10:28 AM | 顯示全部樓層 |閱讀模式
售~ 充電器 , 21000元 .....誠可議價.
近全新,少用. 0929-587-789
[ 本帖最後由 rctony 於 2012年6月16日 12:59 PM 編輯 ]
上一篇:亞拓450鋁箱(已售出)
下一篇:請問華牌UFLY 及 UFLY-S 差別在哪裡呢
發表於 2011年4月23日 10:38 AM | 顯示全部樓層
規格看錯了..
讓給下一位
 樓主| 發表於 2011年4月23日 11:22 AM | 顯示全部樓層
規格如下:
NextGeneration type
next 10.36-12
Weight about830 g
850 g
Size (w / d / h) about160*180*67 mm
Colour of the caseanthracite
Internal fan12 V / 7 W /
55 dBa
Serial port (included)5 V SIO
Optional available in-/outputsincluded
USB + temperature sensor + blinking light + fan
Supply voltage range10.0 - 15.0 V
Under voltage warning11.6 - 10.4 V
- adjusting range
Under voltage warning0.5 V
- cut off below warning
Supply current up to (about)25 A
Quiescent current about ...100 mA
+ current LCD-illumin. (disconnectable, about)50 mA
Trickle charge currents Ni-CdTrickle pulses
Trickle charge currents other battery typesno
Adjustable Lithium voltagesyes
(for full / empty)
Password protected owners nameyes
User setted charge/discharge configurationsyes
Battery 1 Output - Charge circuitnext 10.36-8
Number of voltage measuring inputs8
Ni-Cd / Ni-MH-batteries
cell-count @ 1.65V1*-36 cells
(Nickel-cell)
max. battery capacity Ni-Cd0.1 - 5.0 Ah
max. battery capacity Ni-MH0.1 - 10.0 Ah
Lead / Li-Fe / Li-Io / Li-Po batteries
Number of balancing inputs/outputs8
12
Max. balancing current1:00 AM
Number of Li-Po cells14 cells
Number of Li-Io cells14 cells
Number of Li-Fe cells16 cells
Number of Lead cells23 cells
Max. battery capacity in mAh0.1 - unlimited
Charge powernext 10.36-8
@ charge voltages
next 10.36-12
Charge power @ 12V240 W
car battery voltage about
Charge current @ 1-24V10.0 A
(~1-15 Ni-/~1-6Li-cells) about
Charge current @ 30V8.0 A
(~18 Ni-/~7 Li-cells) about
Charge current @ 40V6.0 A
(~24 Ni-/~9 Li-cells) about
Charge current @ 45V5.3 A
(~27 Ni-/~11 Li-cells) about
Charge current @ 50V4.8 A
(~30 Ni-/~12-Li-cells) about
Charge current @ 60V4.0 A
(~36 Ni-/~14 Li-cells) about
Battery 1 outputnext 10.36-8
- discharge circuit
next 10.36-12
Cell count (@ 1.30 V/Ni- /1-40 Ni-cells
4,00 V/Li-cell)1-14 Li-cells
Discharge power about240 W
@ 12 V car battery voltage
Discharge current @ 1-24 V10.0 A
(~1-18 Ni-/~1-6 Li-cells) about
Discharge current @ 32 V7.5 A
(~24 Ni-/~8 Li-cells) about
Discharge current @ 36 V6.7 A
(~27 Ni-/9 Li-cells) about
Discharge current @ 40 V6.0 A
(~30 Ni-/~10 Li-cells) about
Discharge current @ 49 V4.9 A
(~36 Ni-/~12 Li-cells) about
Discharge current @ 54 V4.4 A
(~40 Ni-/~14 Li-cells) about
Max. discharge power when connected to a fully charged car battery or to an AC/DC power supply100 W
Battery 2 output - charge circuit
next 10.36-12
Ni-Cd / Ni-MH batteries
cell count (@ 1.65V / cell)1*-6 cells
Charge current ~0.1 - 5 A
Charge power @ 13,8 V car batt. & 12V output 2 about60 W
Max. battery capacity Ni-Cd0.1 - 2.5 Ah
Max. battery capacity Ni-MH0.1 - 5.0 Ah
Number of balancing inputs/outputs0
Li-Po cell count1 - 2/3**cells
Li-Io cell count1 - 2/3**cells
Li-Fe cell count1 - 3 cells
Lead cell count1 - 4/5** cells
Max. capacity mAh0.1 - unlimited
GMT+8, 2025年10月5日 05:28 AM
