查看: 3551|回復: 16
分享:直升機的大槳決定一切
發表於 2011年4月12日 09:38 PM | 顯示全部樓層 |閱讀模式
最近在思考,原廠主槳一副要價600元以上,而副廠玻槳一副不到200,對於新手來說,真不曉得差異性在那…
無聊中上網隨便逛…在左岸一個可能不太知名的航模網上看到這篇文章,讓新手的我了解了倒底槳平衡是為了什麼…
轉貼內容:
My dad told me that a helicopter is what blades it uses. I did not really understand this until I ran into some serious dynamic blade balance problems. After my dad and I exhausted all the tweaks we could think of, we decided to swap several sets of blades for AB test. The result was astounding. Blades made big difference in terms of tracking and flight performance. This prompted my dad to in-depth study of blades. I would like to share with you what we found out.
我爸爸告诉我直升机的大浆决定一切。我一直没有真正理解这一点直到有一次遇到严重的大浆动态平衡问题。我们试遍了所有能想到的调整都无济于事,最后决定换浆。结果让我们非常震惊。大浆本身对双浆和飞行性能影响极大。于是我们对浆的性能做了个深入的了解,在这里与大家分享。
I used to help my dad to measure blades’ weight and center of gravity. Now I know that there are three categories of blade measurement, namely dimensional, static and dynamic which affect blade performance. The balance of these measurements between the two blades in the pair is just as important, if not more, as the measurements themselves.(see chart)
我曾帮我爸爸测量浆的重量和重心,现在我知道有三类测量指标影响浆的性能:尺寸,静态指标,动态指标。也许一对浆的这些指标的平衡比指标本身来的更加重要。(见插图)
The dimensional measurement includes length, width, thickness and overall profile. I recall that my dad bought a pair of glass fiber blades. Out of the box, they were at slightly different dimensions.
尺寸测量包括长度,宽度,厚度和截面形状。记得我爸爸曾经买过一对尺寸不太对称的玻纤浆。
The static measurement includes weight, center of gravity, static lead lag, bending stiffness and torsion stiffness. I have a pair of carbon fiber blades with dynamic tracking problem caused by imbalance of bending stiffness.
静态测量包括重量,重心,静前沿滞后,弯曲钢度,和扭区钢度。我有一付碳纤浆,总是动态双浆,后来发现是弯曲钢度不对称引起的。
Dynamic measurement includes dynamic balance, power efficiency and servo load. The servo load is highly influenced by static lead lag angle.
动态测量包括动态平衡,功效和舵机载荷。舵机载荷对静前沿滞角度后很敏感。
Generally speaking, stiffer blades are better for hard 3D flight and less stiff blades are appreciated by graceful F3C pilots. Regardless stiffer or soft, they need to be balanced in all aspects.
一般说来,钢度强的浆适合于剧烈型的3D飞行,钢度弱的浆更受优美的F3C飞手青睐。不管硬还是软,一付浆的各项指标的平衡是最重要的。
Next time if you can not get your blades to track properly all the time, look at the blades themselves!
下次如果你发现无法使你的大浆在各种飞行条件下都无双浆,建议不妨查一下您的大浆!
本文引用地址:http://www.w1wmx.com/article/2008/0607/article_117.html
作者:tttoy2man
原文:直升飞机的大浆决定一切([url]http://www.w1wmx.com/article/2008/0607/article_117.html
)[/url]
上一篇:北市適合夜航的地點?
下一篇:大家是如何做好電直後勤呢?
發表於 2011年4月13日 02:50 AM | 顯示全部樓層
恩..寫的真好對新手而言上了寳貴一課.
發表於 2011年4月13日 07:32 AM | 顯示全部樓層
連一個槳也有這麼大的影響;這對剛入門的新手是很重要的觀念,又學到了一個基本功...受教了
發表於 2011年4月13日 08:18 AM | 顯示全部樓層
這本來就是基本常識,可是現在的飛友都只關心價格,所以   講了也是白講
發表於 2011年4月13日 02:58 PM | 顯示全部樓層
就是這樣,所以一個近千元的槳平衡器
(信天翁 2~5mm 通用版)我毅然決然地
給它敗下去,效果只有一個字:讚!
以前平衡不了丟棄的那些槳真是可惜了 :'(
 樓主| 發表於 2011年4月13日 05:42 PM | 顯示全部樓層
原帖由 shouzama 於 2011/4/13 14:58 發表
就是這樣,所以一個近千元的槳平衡器
給它敗下去,效果只有一個字:讚!
呵…shouzama大真不惜重資,害我看到手上2XX的槳平衡器想要丟掉也來換一個…XDDD
PS:機子雖然只有2台,但工具投資越來越多…慢慢開始覺得是個錢坑了
GMT+8, 2025年11月14日 02:47 PM
