查看: 922|回復: 3
[電子設備] SCHULZE 7.36-12 頂級充電器
發表於 2011年2月15日 06:33 PM | 顯示全部樓層 |閱讀模式
next 7.36-12
Universal charger / discharger
1-36 Ni-, 1-14 Li-cells
With integrated
balancer
for
up to
12 Li-cells
Output 1:
7 A
Output 1:
3 A
Inclusive of "nextConn-Set"
the PrintedCircuitBoard with
numerous user interfaces.
Hint:
If your Lithium battery is not fitted with our BalCab20 connector then you possibly are in need of one of our
BalAd-XX balancing-adapters (Accessories) to balance big packs.
with 19% V.A.T.
349.00 €
Shipping costs
without V.A.T.
(293.28 €)
Features
Specifications
Operating instructions
Firmware Update
USB driver
Accessories
NextGeneration typenext 6.30-6next 7.36-8next 7.36-12next 10.36-8next 10.36-12
Weight about760 g810 g830 g830 g850 g
Size (w / d / h) about160*180*67 mm160*180*67 mm160*180*67 mm
Colour of the caseblueblueanthracite
Internal fan12 V / 1.1 W /
32 dBa
12 V / 1.1 W /
32 dBa
12 V / 7 W /
55 dBa
Serial port (included)5 V SIO5 V SIO5 V SIO
Optional available in-/outputs
USB + temperature sensor + blinking light + fan
not includedincludedincluded
Supply voltage range10.0 - 25.0 V10.0 - 25.0 V10.0 - 15.0 V
Under voltage warning
- adjusting range
11.6 - 10.4 V11.6 - 10.4 V11.6 - 10.4 V
- cut off below warning
0.5 V0.5 V0.5 V
Supply current up to (about)16 A25 A25 A
Quiescent current about ...100 mA100 mA100 mA
+ current LCD-illumin. (disconnectable, about)50 mA50 mA50 mA
Trickle charge currents Ni-CdTrickle pulsesTrickle pulsesTrickle pulses
Trickle charge currents other battery typesnonono
Adjustable Lithium voltages
(for full / empty)
yesyesyes
Password protected owners nameyesyesyes
User setted charge/discharge configurationsyesyesyes
Battery 1 Output - Charge circuitnext 6.30-6next 7.36-8next 7.36-12next 10.36-8next 10.36-12
Number of voltage measuring inputs8812812
Ni-Cd / Ni-MH-batteries
cell-count @ 1.65V
(Nickel-cell)
1*-30 cells1*-36 cells1*-36 cells
max. battery capacity Ni-Cd0.1 - 3.0 Ah0.1 - 3.5 Ah0.1 - 5.0 Ah
max. battery capacity Ni-MH0.1 - 6.0 Ah0.1 - 7.0 Ah0.1 - 10.0 Ah
Lead / Li-Fe / Li-Io / Li-Po batteries
Number of balancing inputs/outputs6812812
Max. balancing current1 A1 A1 A
Number of Li-Po cells12 cells14 cells14 cells
Number of Li-Io cells12 cells14 cells14 cells
Number of Li-Fe cells13 cells16 cells16 cells
Number of Lead cells19 cells23 cells23 cells
Max. battery capacity in mAh0.1 - unlimited0.1 - unlimited0.1 - unlimited
Charge power
@ charge voltages
next 6.30-5next 7.36-8next 7.36-12next 10.36-8next 10.36-12
Charge power @ 12V
car battery voltage about
150 W240 W240 W
Charge current @ 1-24V
(~1-15 Ni-/~1-6Li-cells) about
6.0 A7.0 A10.0 A
Charge current @ 30V
(~18 Ni-/~7 Li-cells) about
5.0 A7.0 A8.0 A
Charge current @ 40V
(~24 Ni-/~9 Li-cells) about
3.7 A6.0 A6.0 A
Charge current @ 45V
(~27 Ni-/~11 Li-cells) about
3.3 A5.3 A5.3 A
Charge current @ 50V
(~30 Ni-/~12-Li-cells) about
3.0 A4.8 A4.8 A
Charge current @ 60V
(~36 Ni-/~14 Li-cells) about
-.- A4.0 A4.0 A
Battery 1 output
- discharge circuit
Cell count (@ 1.30 V/Ni- /
4,00 V/Li-cell)
1-33 Ni-cells
1-12 Li-cells
1-40 Ni-cells
1-14 Li-cells
1-40 Ni-cells
1-14 Li-cells
Discharge power about
@ 12 V car battery voltage
150 W240 W240 W
Discharge current @ 1-24 V
(~1-18 Ni-/~1-6 Li-cells) about
6.0 A7.0 A10.0 A
Discharge current @ 32 V
(~24 Ni-/~8 Li-cells) about
4.7 A7.0 A7.5 A
Discharge current @ 36 V
(~27 Ni-/9 Li-cells) about
4.2 A6.7 A6.7 A
Discharge current @ 40 V
(~30 Ni-/~10 Li-cells) about
3.7 A6.0 A6.0 A
Discharge current @ 49 V
(~36 Ni-/~12 Li-cells) about
-.- A4.9 A4.9 A
Discharge current @ 54 V
(~40 Ni-/~14 Li-cells) about
-.- A4.4 A4.4 A
Max. discharge power when connected to a fully charged car battery or to an AC/DC power supply50 W50 W100 W
Battery 2 output - charge circuitnext 6.30-6next 7.36-8next 7.36-12next 10.36-8next 10.36-12
Ni-Cd / Ni-MH batteries
cell count (@ 1.65V / cell)1*-6 cells1*-6 cells1*-6 cells
Charge current ~0.1 - 3 A0.1 - 3 A0.1 - 5 A
Charge power @ 13,8 V car batt. & 12V output 2 about36 W36 W60 W
Max. battery capacity Ni-Cd0.1 - 1.5 Ah0.1 - 1.5 Ah0.1 - 2.5 Ah
Max. battery capacity Ni-MH0.1 - 3.0 Ah0.1 - 3.0 Ah0.1 - 5.0 Ah
Number of balancing inputs/outputs000
Li-Po cell count1 - 2/3**cells1 - 2/3**cells1 - 2/3**cells
Li-Io cell count1 - 2/3**cells1 - 2/3**cells1 - 2/3**cells
Li-Fe cell count1 - 3 cells1 - 3 cells1 - 3 cells
Lead cell count1 - 4/5** cells1 - 4/5** cells1 - 4/5** cells
Max. capacity mAh0.1 - unlimited0.1 - unlimited0.1 - unlimited
SCHULZE 頂級充電器 約買一年多  使用正常  已經升級成最新版本
平衡後電池電壓差異可在mV範圍內  非常準
可以接電腦界面  網路升級
平常使用10S電池充電  電流可以到5A
可以支援到14S  內建平衡到12S
以加購支援2.54mm的平衡轉接座
亞拓/海波浪等常用的平衡頭都可以使用
因為升級大瓦數充電器含淚求售
NT 12000  可接受再PM  不議價  謝謝  已先PM者優先購買  感恩
[ 本帖最後由 herbalist 於 2011年2月15日 06:36 PM 編輯 ]
上一篇:Futaba GY401 自取1550!
下一篇:德製KONTRONIK TANGO 45-07 KV720 無刷內轉馬達
 樓主| 發表於 2011年2月15日 06:37 PM | 顯示全部樓層
附註:
原廠的盒子  配件  說明書均完整  謝謝
 樓主| 發表於 2011年2月16日 11:19 AM | 顯示全部樓層
附加實際充電情況的示意圖轉連自國外討論區
 樓主| 發表於 2011年2月18日 04:45 PM | 顯示全部樓層
看樣子CP值太低了不好賣  還是自推一下 ><
GMT+8, 2025年7月5日 11:52 AM
