站台備份資料還原至 2026-01-15_04-30
還是有些問題在 開啟站先 明天再戰
查看: 12878|回復: 35
全新代理 PowerLab8 大功率1000W充電器 第一批已全數售出!
發表於 2010年7月14日 11:52 PM | 顯示全部樓層 |閱讀模式
今天與 Cellpro PowerLab8 公司取得台灣區代理,讓各位模型愛用者取的最好的服務,第一批預購者需付1/4訂金,以便作業,如需購買請PM或0939-535-598來電洽詢!
Cellpro POWERLAB 8 是一款高科技的頂級充電器, 最大功率1000W, 遠超越目前市售充電器規格, 能夠充電, 放電, 監測, 或執行多組循環, 針對目前市售電池以驚人的速度充放循環, 是一款極高效率的充放電器.
適用電池種類: 鋰聚, 鋰璃子, 鋰錳, A123(Li-Fe)磷酸鐵, 鎳鉻, 鎳氫,
6V, 12V, 24V
鉛酸電池.
充電容量: 20mah – 360AH
輸入電壓: 20-32V(極性錯誤保護)
充電電流: 10Ma – 30A
*** 原廠公司貨, 每台充電器皆有代理商標籤, 具備後續售後維護 ***
預計八月份正式公開銷售, 即日起優惠預購到2010/7/16止.過此優惠回復售價!
1.單機版本 預購價:7800元免運費 需付訂金每台:2000元
2.套裝版本 Combo 預購價:9500元免運費 需付訂金每台:2500元
如需購買請PM給我.付訂金匯款後須留後五碼.電話.姓名.地址.以利作業!
參照原廠數據以下:
For Battery types: Lithium Polymer (1s to 8s balanced, 1s to 2s unbalanced), Lithium Ion (1s to 8s balanced, 1s to 2s unbalanced), Lithium Manganese (1s to 8s balanced, 1s to 2s unbalanced), A123 (LiFePO4) (1s to 8s balanced, 1s to 10s unbalanced), NiCd (1s to 21s), NiMH (1s to 21s), 6v, 12v, 24v Lead Acid batteries (Flooded, Gel, AGM, SLA)
Pack capacity: 20 mAh to 360Ah
Input voltage: 10-32VDC, reverse polarity protected
Input current: 1A to 50A, software limited
Power conversion: Synchronous DC/DC converter, supports multiple switcher frequencies of 31.25 kHz, 62.5 kHz, 125 kHz; user selectable by preset, 85% to 93% efficiency depending on output current
Output battery charge current: Adjustable range 10mA to 30A, limited by 50A input current*
Output battery discharge current: Internal discharge 10mA to 10A, 100W max Regenerative discharge 10mA to 30A, 1000W max**
Continuous max output power: 516W @ +12VDC input, 1008W @ +24VDC
Cell balancing: Resolution 78uV (16 bit) for 1s-8s Li or A123 (LiFePO4) balanced charging
Voltage calibration: Cell voltage measurements are factory calibrated to a standard traceable to NIST; calibration is to +/- 6 mV
Current calibration: Charge current is factory calibrated on a 4A standard; calibration is to +/- 1mA
Measurement accuracy:
Voltage resolution: 78uV (16 bit)
Voltage tolerance: +/- 6mV
Charge current: +/- 1%
Capacity added to pack: +/- 1%
Percent capacity (“Fuel”): +/- 5% (with accurate fuel table defined for battery being charged)
Serial data output: 19.2kbps, 8 bits, 1 start bit, 1 stop bit, no parity
Data integrity: Checksum, CRC checking
Cooling fans: Twin, 13 CFM, 50mm diameter
Heat sink: Internal 200W aluminum, thin finned
Output battery connector: “Cellpro” compatible, JST PA series, 9 position
LCD: 2 line, 16 character, light grey/blue backlit
[ 本帖最後由 小及 於 2010年9月10日 02:09 PM 編輯 ]
上一篇:最新到貨 AUOT BOOSSTER 自動點火系通!
下一篇:原廠 Amass XT60 & 一般市售XT60 的比較
發表於 2010年7月15日 01:55 AM | 顯示全部樓層
大好了,原來的代理商怕衝擊到自己賣的產品,請他進貨,死也不進貨.
現場有看過我操作的人,都會想把自己充電器丟掉換這一台,衝擊100%一定會發生.
如果有人可以代理提供合理價格,且提供服務及配件是一件非常好的事.也省得我幫人下單網購了.
這一台操作邏輯有異於一般,最好翻譯一份中文說明檔.否則看不懂英文的人"摸"不出來,尤其是並聯充電是歐美最近興起的方法,要教導正確使用.
祝生意興隆
發表於 2010年7月15日 08:39 AM | 顯示全部樓層
這樣的話,也順便代理Co-Pilot II吧
 樓主| 發表於 2010年7月15日 05:02 PM | 顯示全部樓層
全新代理 PowerLab8 大功率1000W充電器簡配版 預購活動開跑!
[ 本帖最後由 小及 於 2010年7月15日 07:02 PM 編輯 ]
 樓主| 發表於 2010年7月15日 05:17 PM | 顯示全部樓層
原帖由 kris000 於 2010年7月15日 01:55 AM 發表
如果有人可以代理提供合理價格,且提供服務及配件是一件非常好的事.也省 ...
目前只有你kris000大大你第一個 有始用心得~聽飛友的建議目前會引進二種商品配件版本~還有要麻煩你說明一下配件使用的說明!
發表於 2010年7月15日 05:52 PM | 顯示全部樓層
套裝版是我最想買的combo 2,建議飛友買這個版本,配件就是並聯充電用的,也有USB連接線,連接電腦用起來才方便,
GMT+8, 2026年1月20日 01:16 AM
