查看: 2148|回復: 2
JR RS10DS十動全頻接收機 如何設定頻率?
發表於 2010年1月24日 11:06 AM | 顯示全部樓層 |閱讀模式
請問 JR RS10DS十動全頻接收機 如何設定跟 JR 9x2 一樣頻率?  之前有用過,不過忘記了! 知道之大大可以告知嗎?
上一篇:T-REX 700E 改成接近3C機
下一篇:我的另一台90E
 樓主| 發表於 2010年1月24日 12:28 PM | 顯示全部樓層
I found it below .Thank you !
Changing Operating Channels:
1. Turn the power switch of the transmitter to “On” and have the transmitter located very close to the receiver and/or airplane with the receiver installed.
2. Apply power to the receiver. The receiver LED should glow.
3. Using a small instrument, depress the “Scan” button until the receiver LED turns off, then release the button. The LED will remain off for approximately 3 seconds.
4. While the LED is off, depress the “Scan” button once again. The receiver LED will flash for a short period while the receiver scans for the strongest frequency. When the receiver has locked onto its new frequency, the receiver LED will return to a solid glow, indicating the receiver is ready for operation.
5. Your receiver will remain locked onto this new assigned frequency
until you,
the user, initiate this change sequence again.
6. Be sure to perform a range check following the instructions
provided with your radio system before flying on the new
frequenc
y choice.
發表於 2010年1月24日 02:09 PM | 顯示全部樓層
掃頻不是嗎?按住按鈕待燈閃爍,再按一次自己掃頻掃到就橫燈,如果掃不到就是你發射頻率超出範圍了
GMT+8, 2026年1月1日 07:21 AM
