查看: 927|回復: 1
Mechanical Fish
發表於 2009年7月5日 11:41 PM | 顯示全部樓層 |閱讀模式
New to the popular Robocraft Series is the Mechanical Fish. The movement of the crank arm is translated into the tail's left and right movement allowing it to swim. As opposed to the previously released blowfish (Item 71114), which had its body above the water, the upper half of this item acts as a float and allows the dorsal fin to be exposed to the surface with the rest of the fish totally submerged as it swims.
By changing the angle of the tail you enjoy watching your fish swim in circles. It is possible to change the angle of the lower body fins. The upper float has a plastic case with styrene foam. Requires separately available R03/AAA/UM4 battery x 1pc. No cement required for assembly.
上一篇:台南船模競賽
下一篇:船友自製mono-1防翻隔艙
發表於 2009年7月6日 10:46 PM | 顯示全部樓層
這個好玩
給他放大改rc一定粉有趣
感謝分享
GMT+8, 2025年12月25日 12:51 AM
