查看: 2085|回復: 7
Tamiya 6.6 V 鋰電池
發表於 2009年6月18日 02:08 AM | 顯示全部樓層 |閱讀模式
Tamiya LF Battery LF2200-6.6V Racing Pack
Tamiya LF-6.6V Battery DC Charger
上一篇:Much More 焊座
下一篇:遙控車廣告片~~
發表於 2009年6月18日 07:27 AM | 顯示全部樓層
這應該是鋰鐵電池~~~不知台灣是否已經開始賣了~~~??????
發表於 2009年6月18日 08:15 AM | 顯示全部樓層
Translation from Tamiya :
Tamiya LF Li-Fe LF2200-6.6V Rechargeable Battery
Item No: 55102
RC is a lithium ion battery charging pack of high-performance formula of high energy density for the model was developed. Suitable for fast charging, and with excellent discharge characteristics that can be discharged, is also characterized safety profile. “Self-discharge” is very low, typical rechargeable battery “memory effect” to prevent, eliminate the need for maintenance and improve the condition of the battery using the discharger. It can be about 1000 times the charge and discharge. It can play a large current without loss deans connectors use is possible for a secure connection and equipped with KONEKUTAKABA. Furthermore, with Tamiya ESC (speed controller) was set to convert the connector connection. In addition, the cells inside the battery pack includes a book and a connector for charging the appropriate balance can be recharged up to this voltage difference.
Source : Tamiya
發表於 2009年6月18日 08:16 AM | 顯示全部樓層
Item No.55103
Available : Jan 31, 2009
Tamiya is the LF-6.6V battery charger for high performance. Supply direct current (DC power) to supply or 12V automotive battery can be charged to secure the simple one-button operation. In addition, LF-6.6V is connected to the connectorsthe battery charger that came with the balance, the individual can keep the proper balance between charging the battery cell voltage. He also connected with the protection circuit, the main battery power and to protect the course. for
※ AC100V to use the power supply is required sold separately.
發表於 2009年6月18日 08:17 AM | 顯示全部樓層
Tamiya LF Battery LF2200-6.6V Racing Pack & LF-6.6V Battery DC Charger Set
Item No.55104
LF-6.6V This would align the first set of batteries. LF-6.6V LF-6.6V has a dedicated battery charger. And are some great prices on more than Alignment alone.
Three major characteristics of the battery ~ LF ~
【 By about 1000 times longer life! 】- About 1,000 of the charge and discharge times.  Moreover, using a dedicated charger can be recharged in 20 minutes, the battery charger 2 is repeated with alternating running and if you have a book you can enjoy all day.  In addition, Ni-MH battery Ni-MH3700 weight as light as it is about half that.
【  By the same capacity! 】 Charge: battery-specific “memory effect” because no, you can recharge the battery as soon ran OK.  Running time will be shorter.  Also, with the balance of the charging connector included, once you maintain an optimal balance between the capacity of each cell can charge.
【  Requires no maintenance ! 】 – After practice, you improve the condition by connecting the instrument does not discharge the battery.  Also, almost no self-discharge, long-term storage is possible if a charge of about half.
※ LF and RC Car RC battery was developed for driving the tank.  Other applications (ENJINSUTATABOKKUSU TW, portable soldering iron, and SUPUREWAKUBESHIKKUKONPURESSASETTO) Please do not use.  ※ After use, when the battery is hot, please lower the temperature from the charge later.
Source : Tamiya
發表於 2009年6月18日 08:51 AM | 顯示全部樓層
阿文兄看不懂啦^_^"
麻煩請您翻譯給我們看吧~ㄏㄏ
今天是在麥帥下面還是石壇公園呢?
GMT+8, 2025年9月13日 03:12 AM
