台灣遙控模型-RCTW
查看: 3179|回復: 0
☆大都會☆AXIAL SCROPION 1/10 (組裝完成RTR)電動攀岩車
發表於 2009年1月13日 01:36 PM | 顯示全部樓層 |閱讀模式
PART #AX90002 - AX10 SCORPION RTR
Features
  • Wheelbase: 304mm~320mm (12”~12.6”)
  • Width: 254mm (10”)
  • Height: 156mm (6.125”)
  • Weight: 1588g (3.5 lbs)
  • Complete ready to race/crawl out of the box
  • 4WD
  • 27T Electric Motor
  • 20T pinion paired with an 87T spur gear gives you a quick rock racer ratio, or install the included 14T pinion for a slower rock crawling ratio.
  • True Beadlocks: No Messy Glue!
  • Hi-quality Composite Plastic and Metals
  • Durable (ESC) Electronic Speed Controller: Hi-quality durable forward and reverse speed controller.
  • Hi-Torque Servo help hold your line when rock crawling
  • Solid Rear Axle lockouts improve ground clearance when crawling
  • Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain.
  • Aluminum Chassis plates with a molded nylon skid plate provide a solid and rigid chassis
  • Ultra compact and lightweight transmission
  • Open front diff for smaller turning radius, or install the included front locker for more traction when rock climbing!
  • Rear axle is locked for better traction.
  • Full Ball bearings
  • Overall gear ratio range from 15:1 to 74:1
  • Transmission: 2.6:1; center mounted
  • Differentials: Front - gear differential; Rear - locked (spool)
  • Transmission: Single-speed
  • Tires: Axial 2.2 Rock Lizards
  • Wheels: Axial 2.2 8 Hole Beadlocks (Satin Chrome)
  • Suspension: 3 Link
  • Drive Shafts: Universal front and rear
Chassis
  • Articulation: 70°
  • Ground Clearance: 79mm (3.125”)
Body
  • Length: 438mm (17.25”)
  • Width: 181mm (7.125”)
  • Height: 133mm (5.25”)
[size=+0]Electronics
  • Radio: 2 Channel
  • Servos: 1 Hi-Torque (Standard Size)
  • Forward/Revers ESC
  • Motor: 27T 540/550 Size
上一篇:☆大都會☆海攻 80-330
下一篇:☆大都會☆KO EX 10 太陽神 遙控器
GMT+8, 2024年4月25日 04:41 PM
Powered by Discuz! X3.4
© 2001-2023 Discuz! Team.
