台灣遙控模型-RCTW
查看: 11440057|回復: 25
JR 12X規格
發表於 2007年7月26日 08:09 PM | 顯示全部樓層 |閱讀模式
原廠資訊 http://www.jrpropo.co.jp/radio/products/propo/air/pcm12x/helicopter.html
Basic Functions
  • Servo Reverse
  • Travel Adjust
  • Dual Rate/Expo : 2 Types : Each Flight Mode
  • Sub Trim
  • Analog Throttle Trim
  • Servo Speed : 2 Types : Every Flight Mode
  • Advanced Digital Trims : Every Flight Mode
  • Programmable Mix : 8 Lines/Curve mixing, 5 Lines Selectable (with EXP)
  • Trim Step / Trim Type
  • Double bearing Sticks with adjustable tension
  • DSC Connector
  • Model Select / Copy : 20 Model memories
  • Model Name : 16 Characters Maximum
  • Flight Mode name : 7 Character Maximum
  • Data Reset
  • Fail Safe when in PCM
  • Alarm / Timer : 2 Lines
  • Modulation Select : APCM (12 Ch), SPCM (10Ch), PPM (8/12 Ch)
  • Servo Monitor with Test Function
  • Trainer System : 2 Types selectable
  • Type Select : 3 Types, Heli, Aero & Glider
  • Data Transfer: Tx <=> Tx, Tx<+> PC
  • Band Select : Synthesised Channel Select 55 -90
  • Device Select
  • High Density LCD with Backlight
Helicopter Functions
  • Flight Mode : Max 6 Lines
  • Throttle Curve : Max 5 Lines Multipoint (with EXP)
  • Pitch Curve : 6 Lines with Multipoint (with EXP)
  • Tail Curve : 5 Lines (with EXP)
  • Throttle Hold : Automatic cut
  • Gyro Adjust : Sensitivity Max 6 Lines/Tail Lock Gain Max 6 Lines
  • MIX Throttle
  • Dual Pitch MIX
  • Governor Adjust : Every Flight Mode
Aeroplane Functions
  • Flight Mode : Max 5 Lines
  • Throttle Curve : Every Flight Mode (with EXP)
  • Pitch Curve : Every Flight Mode (with EXP)
  • Throttle Hold
  • Gyro Sensitivity Adjust : 2 Types
  • AILE --> RUDD MIX : With Differential
  • ELEV --> FLAP MIX
  • RUDD --> AILE/ELEV MIX
  • AILE --> FLAP MIX
  • Flap System
  • Snap Roll : Independant 4 Lines
  • Wing Type Adjust : With Differential / Balancer
Glider Functions
  • ELEV --> FLAP MIX : Every Flight Mode
  • AILE --> RUDD MIX : Every Flight Mode
  • AILE --> FLAP MIX : Every Flight Mode
  • RUDD -->SPOI MIX : Every Flight Mode with Spoiler offset
  • Flaperon MIX : Every Flight Mode with flap lever offset
  • Flap Rate : Every Flight Mode
  • Differential : Every Flight Mode
  • Flight Mode Delay
  • Brake System
  • Motor Hold
[ 本帖最後由 rc.kevin 於 2007年7月26日 08:24 PM 編輯 ]
上一篇:好聽的引擎聲(要開喇叭喔)
下一篇:果然很大隻
發表於 2007年7月27日 12:38 PM | 顯示全部樓層
太好了!就等它上市了!
發表於 2007年7月27日 09:31 PM | 顯示全部樓層
正呀~我喜歡
 樓主| 發表於 2007年7月27日 10:18 PM | 顯示全部樓層
即將上市的是SPCM版的,非2.4G.  外面模型店不含Server要3.5k.  根據原廠價格換算這個版本全配SYSTEM J12HTR &#20385;格 147,000&#20870;(&#31246;&#25244;\140,000)
= 台幣38,781
發表於 2007年7月27日 10:39 PM | 顯示全部樓層
原帖由 rc.kevin 於 2007年7月27日 22:18 發表
= 台幣38,781
這樣如果扣掉接收伺服應該在30000左右吧??!!
不曉得他螢幕會不會發亮A??
跟9X2的模組不曉得可以共用嗎?
發表於 2007年7月28日 12:18 AM | 顯示全部樓層
原帖由 richar980850 於 2007年7月27日 10:39 PM 發表
不曉得他螢幕會不會發亮A??
跟9X2的模組不曉得可以共用嗎?
12X的發射模組是TSM-40J/TSM-72J-DDS,9X2的模組TS-40J/TS-72J(TW)-PLLS,不能共用喔∼∼
此外,JR官網上面,發射機+接收機的日幣價格147,000&#20870;(&#31246;&#25244;\140,000)。全套發射機+接收機+伺服機DS8325×4的日幣價格199,500&#20870;(&#31246;&#25244;\190,000),與FUTABA的全套12Z價格相當喔!
GMT+8, 2024年4月28日 05:06 PM
Powered by Discuz! X3.4
© 2001-2023 Discuz! Team.
