本帖最後由 ckflyer 於 2020年10月25日 10:26 PM 編輯
房間要還給兒子了
4台合計 $7,500 電裝價, 暫不分售, 新手不要來,
Kyosho YS-11, Unique F4U, Dynam FW-190, 全電裝不含接收
Pro Design F-18 缺電變, 風鼓 不含接收
中彰投1高,3高,74號道, 中投等約交流道面交
工作忙, 無誠誤試, 以方便面交優先, 二手品, 無保固, 售出不退
Kyosho YS-11 民航機 (海上保安廳)
玻璃纖維機身, 巴爾莎木機翼
全電裝含燈光組右翼有修補過
用3S 2200mah, 要加2S 800mah 給接收及燈光組
Unique F4U F-4U, 全電裝 含收輪, 機翼有補強黏在一起(本來是對拆的), 少了前座倉罩, 忘記要不要BEC了
Specification:
Material: EPO
Wingspan: 1200mm
Length: 1000mm
Height: 450mm
Wing Motors: 1 * 3648 480KV Brushless motor
ESC: 1 * 40A brushless ESC
Servo: 7 * 9g servos
Propeller: 4-Blade 13 * 6in
Flying Weight: 1450g
Required Battery: 4S 25C 2200mAh~2600mAh Li-po battery
ProDesign F-18 90EDF (有PDF 說明書)
空機含五個全新伺服機:1個9G, 2個17G, 2個JR539
Specification
• Flying Weight ~3400g (~7.5 lb)
• Wing span 920mm / 36.2 in.
• Length 1250mm / 49.2 in.
• Rotor diameter 90mm / 3.54 in.
Radio system for 4 channels or above
1x Electronic speed controllers for brushless motor
1x 90mm fan-units, EDF shaft adapter diameter 5mm
1x 1000-1500W size brushless motors
6-8s Lipo battery for 1600kv brushless motor
4x Servo extension wires
2x Metal gear standard size servo, for elevator
2x 9g servos for ailerons.
5 or 30 minute epoxy, CA Glue
Velcro.
Dynam Focke Wulf FW-190 1270mm
全電裝, 有改襟翼
Specifications:
Material: EPO Foam
Wing Span: 1270mm(50in)
Wing Loading: 53.7g/dm2
Fuselage Length: 1110mm(43.7in)
Center of Gravity: 70 - 75mm from the leading edge at the wing root
Motor: Detrum BM3720A-KV500
ESC: 40A Brushless
Propeller: 3-Blade Scale Prop
Servo: 4x 9g
Elevator: Yes
Rudder: Yes
Ailerons: Yes
Flaps: No
Landing Gear: E retract
Kyosho YS-11
Unique F4U
ProDesign F-18
Dynam FW-190
Dynam FW-190
Unique F4U
▼ 下一篇:[已成交]小橘7動+Spektrum小衛星[5000元]T-MOTOR U10 100KV電機▲ 上一篇:
