本帖最後由 大頭啊 於 2018年12月13日 10:47 AM 編輯
Features: • Clear Canopy with Pilot • Easy-Access Top-Hatch • Factory-Painted Cowl with Dummy Cylinders • Factory Laser-Cut, Jig-Built Assembly • All-Wood Construction • Factory Covered and Finished • Compatible with Electric Power Systems • Hardware Package for EP Specifications: • Wingspan: 1220mm (48 Inches) • Wing Area: 25.6sq.dm (397 Square Inches) • Wing Loading: 62.5g/dm.sq. (21 Ounces Per Square Foot) • Length: 1000mm (39.4 Inches) • Minimum Weight Ready to Fly (Will Vary w/Equipment Used): 1.6Kg (3.5 Pounds) Recommended Items Required: • 4 to 6 Channel Radio • (4) x 9 Gram Servos • For Electric Power: 2814 Motor, 60 Amp BL ESC, 3S 2200mAh LiPo and 9 x 4.5E Propeller
西盛可面交
做工細緻精美完成度剛
