5400mAh ,30分鐘續航時間
Follow me,Watch me 智能跟隨
ST10+ 加大5吋半大觸控螢幕,Android平台,直接圖傳,不用另接螢幕,內置圖傳接收,GPS
螢幕可切換中文字幕,一目了然
日本,美國手,遙控器內設定切換
CG02+ HD camera 3軸雲台,1080P攝影機
非常易於操控,RTF到手即飛可以用帶有802.11n的wifi平板或手機接收圖傳
FOLLOW ME 跟隨模式& TRACKING ME 追蹤模式
開箱
指南針校正:
加速計校正:
Captures smooth, steady aerial video in brilliant high definition
No-distortion camera lens eliminates fisheye effect
Easy to fly – no experience necessary
Everything in one box
30 minute flight times
Advanced SAFE® Plus technology
Smart Mode for beginner pilots
AP Mode for experienced pilots
Autonomous Follow Me and Watch Me modes
Return Home function
CGO2+ 16MP 1080p/60 camera with integrated 3-axis brushless gimbal
ST-10+ controller with built-in Android display
See live video and telemetry info on controller display
Uses GLONASS and U.S. GPS for greater accuracy and reliability
Mast-mounted GPS antenna for superb signal reception
Micro SD card for camera
3S 5400mAh Li-Po Flight Battery
Li-Po battery charger with AC adapter
Display screen sun shade
USB programmer cable
If you’re looking for an easy way to jump into the exciting world of HD aerial photography, the Blade® Chroma™ AP Combo has everything you need.
CGO2+ Camera: Brilliant HD Video and Photos The included CGO2+ combines a high-definition camera and stabilization gimbal into a single unit that captures steady aerial video and stills in brilliant detail. All camera controls are placed within easy reach on the included ST-10+ controller. Camera features include:
• 1080p/60fps video
• 16MP photo
• No-distortion lens – eliminates fisheye effect
• Integrated, 3-axis brushless stabilization gimbal
• Adjustable resolution and frame rate
• Streams live video to the ST-10+
• Can stream live video to multiple mobile devices*
*Requires iOS or Android device with 802.11N Wi-Fi connectivity and the free CGO app.
ST-10+ Controller: Everything at Your Fingertips The ST-10+ controller puts all camera and drone functions at your fingertips.
• Large, 5 ½ inch touch-screen display with intuitive Android interface
• Displays live video and real-time telemetry info like speed, altitude and battery voltage
• Clearly marked switches and buttons
• Super-simple flight and camera controls
• Slider switch for adjusting camera tilt
• Slider switch for adjusting drone speed
SAFE® Plus Technology: Look Like a Pro SAFE Plus technology gives you several flight modes that have been specially programmed to make smooth, steady image capture easy – even if you’ve never flown a drone before! All feature self-leveling and use GPS and altitude sensors to precisely hold position. SAFE Plus technology will even land the aircraft for you if you activate the Return Home function.
Smart Mode Perfect for first-time drone flyers.
• Stick Relativity moves drone in whatever direction the control stick is pushed, no matter which way the nose is pointed
• Creates a SAFE Circle™ barrier that prevents the aircraft from flying too close to you
• Auto-holds position and altitude when control sticks are released
AP (Aerial Photography) Mode For more experienced drone pilots.
• Responds like a conventional drone without Stick Relativity
• Gives you greater control authority by turning off the SAFE Circle
• Keeps control response smooth so panning and tracking shots look great
Follow Me Mode Your built-in copilot.
• Frees you to focus on lining up the perfect shot
• Pan and tilt the camera while the drone follows
• Drone follows at an altitude and distance you set
• Resume full control at anytime
Watch Me Mode Be the star.
• Drone follows and keeps the camera pointed at whoever holds the ST-10+ controller
• Resume full control at any time
Return Home Safe landings with the flip of a switch.
• Returns the drone to its start-up point and lands it for you
• Great for first-time flyers who aren’t ready to land themselves
• Easy way to regain visual contact if you lose sight in flight
• Activates automatically if controller signal is lost
• Keeps the drone within altitude and distance limits you define
• Easily adjusted using the Chroma programmer
• Helps you avoid sensitive airspace . . . and neighbors
Everything in One Box
• Flight-ready Chroma drone with stabilized CG02+ HD camera
• ST-10+ controller with touch-screen display
• 5400mAh Li-Po flight battery for 30 min. flight times
• Flight battery charger with AC adapter
• Spare propellers
• ST-10+ screen shade
• USB programmer cable
