The ParkZone Sukhoi SU-29MM was designed by Mike McConville.
This plane is lightweight with a high-output brushless motor that delivers 3D and precision aerobatic performance. It also features a Spektrum AR636 receiver and SAFE technology that makes the Sukhoi SU-29MM aware of its attitude relative to the ground.
SAFE Technology with three modes:
Stability Mode - The Sukhoi can perform any aerobatic or 3D maneuver but will return to upright flight if both sticks are released.
3D Mode - Marvelous balance of crisp response and rock-solid stability when practicing low-speed 3D maneuvers.
Precision Mode - Designed for flying precision aerobatics at high speed, because it smoothes out the effects of turbulence so the aircraft tracks lik it’s on rails.
Panic Recover Mode - Immediately returns the aircraft to upright flight with the push of a button at any time, in any mode.
規格:
Wingspan: 44.0 in (1120 mm)
Overall Length: 42.3 in (1074 mm)
Flying Weight: 40.6 oz (1150 g)
Motor Size: 10-size BL10 brushless outrunner, 1250Kv
