台灣遙控模型-RCTW
查看: 1167|回復: 3
[空/飛機] [★已完成交易★] 全新 未組 翼展1米4 FW-190 材質epo(PNF)
發表於 2012年4月8日 03:49 PM | 顯示全部樓層 |閱讀模式
僅僅拆箱檢查
台中北屯可面交
以版面回覆為準.洲際飛友優先.
相關資料如下
The Focke-Wulf FW190 was a German Second World War single-seat, single-engine fighter aircraft designed in the late 1930s. Powered by a radial engine, the 190 had ample power and was able to lift larger loads than its well-known counterpart, the Messerschmitt BF 109. The 190 was used by the Luftwaffe in a wide variety of roles, including day fighter, fighter-bomber, ground-attack aircraft and, to a lesser degree, night fighter.
This EPO FW190 is an impressive model both in terms of looks and scale detail. With its 3 bladed prop, drop tank and pre-applied waterslide decals, this model really looks the part! Being Plug and fly, there is little to do in terms of building with the powerful motor, ESC & servos pre-fitted. This model features simple to install fixed landing gear yet is retract-ready if you choose to add your own retractable gear. Just add your own radio, receiver, 4S 2200mah lipo and your ready to fly!
Flight performance from this Second World War fighter is excellent. It has a wide flight envelope, capable of realistic scale aerobatics yet also manageable for the less experienced pilot. Due to its larger size, it will also tolerate a little wind making it a very practical model to own. The 1400mm FW190 is a must for the collection of any scale or warbird enthusiast!
Specs:
Wing Span: 1400mm
Length: 1100mm
Flying Weight: 1800g
Motor: 600kv Brushless Outrunner
ESC: 45A w/BEC
Servo: 9g x 4
Requires:
Your Own 4 Channel TX/RX
2200mAh 4s Lipoly Battery
[ 本帖最後由 hfb 於 2012年4月10日 06:43 PM 編輯 ]
上一篇:MS01D FF 含碳刷電變馬達
下一篇:(已徵到):亞拓原廠SPORT旋翼頭
 樓主| 發表於 2012年4月9日 12:10 PM | 顯示全部樓層
推上去
意者pm議價
發表於 2012年4月9日 02:28 PM | 顯示全部樓層
回復 1樓 hfb 的帖子
幫忙推一把XD~
 樓主| 發表於 2012年4月9日 10:27 PM | 顯示全部樓層
原帖由 Welsonpan 於 2012年4月9日 02:28 PM 發表
幫忙推一把XD~
感謝幫推
GMT+8, 2024年5月28日 02:55 PM
Powered by Discuz! X3.4
© 2001-2023 Discuz! Team.
