台灣遙控模型-RCTW
查看: 5793|回復: 10
【童愛模型】美國 DA-60cc汽油引擎 ,新貨到
發表於 2012年3月20日 09:38 PM | 顯示全部樓層 |閱讀模式
去年訂了五顆,大家用的效果真的很好,這次又訂了四顆DA-60已到貨
歡迎飛友訂購不含排氣管
可加購原廠DA-60排氣管3150元
原廠保固三年.
DA 60說明書http://www.troybuiltmodels.com/ns/manuals/DA-60.pdf
DA 60 Single
The DA-60 is the latest high performance offering from Desert Aircraft for planes in the 50cc to 70cc class. At only 1410 g (3.1 lbs), the power to weight ratio is excellent.
The DA reed valve and Walbro carburetor are well matched, providing consistent engine performance at all flight attitudes and throttle settings. Throttle and choke arms are pre-installed.
The engine delivers superb performance while maintaining excellent structural integrity. The rigid integral engine mount and robust, well balanced crankshaft ensure smooth operation. Depending on firewall location, the engine can be mounted without stand offs or spacers, which further eliminates vibration.
The DA-60 with its integral mount weighs less than the DA-50R with standoff mounts, and shows lower vibration levels than the DA-50R. With equal props, the DA-60 out turns the DA-50R by 600+ rpm!
The crankcase is CNC machined from 7075 T6 alloy, while titanium is used for the prop shaft extension.
The exhaust port shape lends itself well to standard style mufflers or tuned exhaust systems that use round headers. This is the same cylinder and piston as used on the well proven DA-120 twin.
As with all DA engines, each DA-60 is thoroughly test ran at the factory before shipping. The best service and support in the industry!
Specifications:
Displacement: 60.5 cc (3.7 c.i.)
Weight: 1410 g (3.1 lbs)
including Ignition: 1517 g (3.34 lbs)
Typical RPM Range: 1200 - 7500 1/min
RPM Max: 9500 1/min
Propellers:
Menz 2-Blade: 22x10", 22x12", 23x8", 23x10", 24x8", 24x10"
Super Silence Carbon 2-Blade: 23x12", 24x10", 24x12"
Super Silence Carbon 3-Blade: 22x10", 22x12"
[ 本帖最後由 cute969211 於 2012年3月20日 09:51 PM 編輯 ]
上一篇:【童愛模型】Prolux鋰電/鋰鐵/鎳氫/鎳鎘/電池液晶測電表
下一篇:【童愛模型】金翼SBACH300 20CC A塗裝,特價6400元~現貨
發表於 2012年3月20日 10:17 PM | 顯示全部樓層
真的是~~毒品~~~阿
小弟也有一顆~~~裝M牌纖維槳........24*8讚~~
發表於 2012年3月20日 10:54 PM | 顯示全部樓層
這應該是搖頭丸
吃了機子保證搖勒~搖勒~
發表於 2012年3月21日 01:03 PM | 顯示全部樓層
這顆贊....
我也有1顆...很兇
發表於 2012年3月21日 01:24 PM | 顯示全部樓層
回復 1樓 cute969211 的帖子
我也有ㄧ顆˙讚˙越飛越爽˙用M牌24*8碳纖槳7500轉˙飛起來真爽
發表於 2012年3月21日 05:38 PM | 顯示全部樓層
大家都說有一顆 我也可以說我也有一顆
只不過還獨缺M牌碳纖槳.........
GMT+8, 2024年5月5日 08:17 AM
Powered by Discuz! X3.4
© 2001-2023 Discuz! Team.
